It is currently Wed Jul 23, 2025 12:24 pm
 Post subject: whats wrong with it
PostPosted: Fri Oct 10, 2008 8:17 am
hey guys my brothr is trying to register his car we had it running out at a mates farm it would run great had all the power in the world bring it home get up the next day it starts but no power and back fires and misses and carrys on like a sick old lady whats wrong with it it is a 1100 motor with 1.5" carbie 12g295 head mild cam of graham russel in it race extractors what are your opinons ??????????????
PostPosted: Fri Oct 10, 2008 8:21 am
check the carb dash pot oil/fluid.
timing?
running lean?
PostPosted: Fri Oct 10, 2008 8:22 am
All the spark plugs firing? Dissy in good order? ummm getting enough fuel as in running too lean/rich.
Thats all i can think of atm sorry.
Oh, come on! If you're in a bus station and they sell postcards for Bizzaro World, you have to assume you're in Bizzaro World, right? I mean, am I crazy?
PostPosted: Fri Oct 10, 2008 8:49 am
condensor or coil maybe
PostPosted: Fri Oct 10, 2008 8:55 am
my clubby did that to me on the side of the monash freeway at 3am. Thanks to a nail file, it turned out the points were a bit crappy, she has purred just fine for the last 6 months. Check your points as well man
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
PostPosted: Fri Oct 10, 2008 9:18 am
Check the distributer clamp or locking bolt(depending on A or A+) , could be loose allowing it to set it's own timing . Also check/adjust/clean the points . How old is the fuel and how well sealed is the tank (how dusty was the farm?) ?
PostPosted: Fri Oct 10, 2008 11:12 am
um everything was good yesterdya dissy real tight everythign but now nothing and fuel is good
PostPosted: Fri Oct 10, 2008 11:31 am
check the general area around the coil for a loose wire?
blokeinamoke wrote:
PostPosted: Fri Oct 10, 2008 4:42 pm
hi all it is my car. dizzy is good petrol good. the thing that gets me is it was running really well then all of a sudden wont even pull you up a hill just stalls.
PostPosted: Fri Oct 10, 2008 5:22 pm
Does it have a fuel filter?
PostPosted: Fri Oct 10, 2008 6:33 pm
no it doesnt.............
PostPosted: Fri Oct 10, 2008 6:43 pm
Just undo the screws that hold the carby dash pot down & have a look to see how flithy the dash pot bell & carby piston is,,, it might be filthy dirty & making the piston stick
does it idle nice at all?
& yeah maybe clean out the carby float bowl & blow thrugh the jet while it`s all apart
at least once you`ve done that then you iknow it`s all good in there anyways & if it isn`t the problem then at least you`ve eliminated that part from the equation,,, it`s not hard to do & you really can`t stuff things up, just remove the bell & piston, clean them both really well & take the float lid off & clean the bowl out & add a fuel filter & see what happens
K?
PostPosted: Fri Oct 10, 2008 7:05 pm
Location: in the shed cutting, grinding and painting my shit
swap out the plugs.
it will have fouled them, most likely have to go one hotter (recommended for the LRP that we have now).
i have had this with one of my older minis, if you idled the car for two minutes before shutting off the engine, it would start on the two centre cylinders. but never would it start on four.
on the other hand, if you pulled a few revs then shut it off, i would always start on four and run fine. it was running a webber, high compression and a big cam, but even my 850 will give me issues if i let it idle too long and just turn it of (i now always carry spare plugs)
Mitch
Matt68 wrote:
I'd like to believe in Karma, however, sometimes I firmly believe we should become the instruments of Karma.
PostPosted: Fri Oct 10, 2008 7:17 pm
ok fellas ill have a look tomorrow at the float etc..... thanks a lot guys ill let yas know how i go
Users browsing this forum: Barkfast and 80 guests
