It is currently Tue Jul 22, 2025 7:38 pm
 Post subject: Trolley Jack
PostPosted: Thu Oct 09, 2008 9:43 am
There was some discussion recently about trolley jacks
Supercrap has a sale on at the moment with a small trolley jack for $27
goes 140mm-330mm - better than the one I have now for the Mini that I paid $10 at a swap meet :roll:
Also picked a an air powered die grinder for $20 - $14 off
David L
 Post subject: grinder
PostPosted: Thu Oct 09, 2008 9:50 am
Rover Cooper
I saw those grinders are they anygood, or just another supercrap disposable item. :roll: :roll: :roll:
PostPosted: Thu Oct 09, 2008 9:57 am
I've only used it briefley with a wire brush - it has 4 speed settings and it only had any umph on the top two - but then I don't know if you are meant to use a 2" wire brush in it :wink:
David L
PostPosted: Thu Oct 09, 2008 7:25 pm
were you looking for the thread David :?:
http://www.ausmini.com/forums/viewtopic ... light=jack
PostPosted: Fri Oct 10, 2008 9:02 am
I went and had a look at the jack, I don't think it's low enough :( I think I will have to buy one like Hanra's... $260 on ebay. Maybe I will just buy a $nap-on one while I'm at it :roll:
PostPosted: Fri Oct 10, 2008 10:12 am
Did you find an Omega one on Ebay? I searched high and low and Rapeco was the only place I could find that would order one in.
PostPosted: Fri Oct 10, 2008 12:56 pm
No it was just a generic brand one, by "like" I meant similar low profile design.
The snap on "the beast" coincidently is only $450...
