It is currently Fri Aug 08, 2025 10:26 pm
PostPosted: Fri Oct 10, 2008 11:04 am
My 1993 Cooper has 60,000 k on the clock with all the service history with it (that I had translated from Japanese to English) so I know it’s genuine. That said, the shocks are the original factory ones and creak a bit and the handling is not what it could be.
The car is fitted with Hi-lows. I went up to Bob Jane and a few other mainstream fitters and all were pushing Monrow shocks. I had Konis fitted to my MPI Cooper and they were great. That OR Spax. Also, they quoted 2 hours labor to fit then @ $90 PH. Sounded right to me.
Any advice would be great guys. Thanks
Its not the size that matters.........
Rover Mini Cooper 1993 spi - current
Rover Mini Cooper 1998 ( Tahti Blue/white)
Rover Mini Cooper 1992 ( Brg),1987 Mayfair
PostPosted: Fri Oct 10, 2008 12:07 pm
Not sure about shocks on Minis specifically but it seems the general consensus on shocks is:-
Bilstein - the most expensive and the best
Konis - expensive and almost as good as Bilsteins, bit harder ride
Spax & Monroe - not nearly as good but do work OK and are cheap
You get what you pay for. Comes down to your budget.
Pete
PostPosted: Fri Oct 10, 2008 12:50 pm
Great feebback thanks very much - I do like a hard ride and no body roll so hopefully this will sort the handeling out
PostPosted: Fri Oct 10, 2008 1:32 pm
I have bilsteins and they're great, but non adjustable - but you don't need to as they are great out of the box.
Koni's are a good choice and slightly cheaper.
Spax and Gaz are OK but of lesser quality from all the people i've spoken too.
KYB are supposed to be a really good choice and are nice and cheap.
2hours fitment is about right including the removal of the tanks (single or twin?) but i wouldn't trust mr. Bob Jane to remove tanks and fit everything correctly. Why not fit them yourself? It's only a couple of nuts and bolts on the front two and a nut on the top of the rear and bolt down the bottom. Only issue is removal of the tank which is not that hard.
PostPosted: Fri Oct 10, 2008 1:43 pm
KYB "Gas-Adjust" are the choice for me for road use,,, they`re a great shock & very reasonably priced,,, they work very very well,,, but just remember if you order them to ask specifically for "Gas-Adjust" as there are KYB std shocks avaliable also,,, they`re 2 totaly different kettles of fish...
PostPosted: Fri Oct 10, 2008 1:55 pm
Great ! Ok, i am learning to Koni`s as i had them already and actually liked the easy ajustable function.
Is it best to order them O.S from MS or locally ?
PostPosted: Fri Oct 10, 2008 2:23 pm
pretty sure the price from MS now will be more expensive than locally with the exchange rate.
I'd get a quote from the Oz supplier and from MS and go with the cheapest :)
PostPosted: Fri Oct 10, 2008 3:10 pm
peterw wrote:
Spax - not nearly as good but do work OK and are cheap
Pete
Ill have to dig up my receipts but im sure i paid about $8-900 for 4 Spax Adjustable Gas Shocks back in 2002.
PostPosted: Fri Oct 10, 2008 3:19 pm
I have adjustable Spax on both my cars - not cheap but as quick as other brands around the track - with a better driver....
However, I keep 3 wheeling around corners and have been told by those in the know that newer type (not sure what brands) keep all 4 wheels on the ground - better travel or something.
I look at it this way.... 3 wheels on the ground have less rolling resistance than 4 wheels - therefore I have to be going faster!
Kuzzy
PostPosted: Fri Oct 10, 2008 3:39 pm
High heel ninja
I was unimpressed with my Koni's & Spax shocks, i now have Bilsteins in my Cooper S, but have recently got a set of GAZ adjustables in from the UK, im super impressed with them, easy to adjust & are cheap to get in direct from the UK.
Doogie
PostPosted: Fri Oct 10, 2008 4:10 pm
I am unimpressed with the Konis I put on Barney, they cost me $150 ea and were so soft I have them adjusted nearly right up tight. Still bouncy over speed humps... :evil:
Bilsteins on Josh's car feel good.. but ride is a bit harder. :wink:
PostPosted: Fri Oct 10, 2008 4:26 pm
When I got my Monroes there were 2 types, Aus made crap ones and Belgium made good ones. That was 10 years ago so I have no idea what they are like now.
M
PostPosted: Fri Oct 10, 2008 7:03 pm
I found the receipts for my Spax, I got them through Fulcrum back in Dec 2001 they were $760 plus $40 freight ($800 all up) for a set of 4 15 point adjustable Gas shocks to suit a lowered car. Not sure how the prices compare these days?
What are Bilsteins and Koni's worth?
PostPosted: Fri Oct 10, 2008 7:08 pm
Got a pair (2) of GAZ adjustables for 280 recently...
PostPosted: Fri Oct 10, 2008 7:25 pm
I Paid $748 for a set of bilsteins from Heasmans.
