It is currently Fri Aug 08, 2025 2:07 pm
PostPosted: Sun Oct 12, 2008 5:38 pm
The new nalothane rack bush is a firm but sliding fit out of the housing but as soon as it is fitted in the housing there is no way the inner rack is going to slide through it - I mean I had to use the BFH to get it in (and out) so what is the trick to reaming nalothane?
David L
PostPosted: Sun Oct 12, 2008 5:44 pm
...there is a line there.....and I dare not take it
1969 Morris 1100 S Automatic
ahhhh......the interior smell of an old British car....
Maybe this should also be added to the "repro parts that just don't fit" thread...
My sympathies for this weekend wombat...nothing seems to be going your way..
PostPosted: Sun Oct 12, 2008 7:00 pm
The Mini King
Are You trying to fit the bush into the housing that had the felt bush fitted, or straight into the Rack housing
PostPosted: Sun Oct 12, 2008 8:11 pm
Straight into the rack housing - There was a red plastic thing in there that was in a metal sleave ( looked like a top steering column bush)- but that had a sloppy fit to the rack and was destroyed getting it out. The new one is blue neoprene/naltothane and is a snug fit into the housing but in the process closes off the bore.
David L
PostPosted: Sun Oct 12, 2008 8:20 pm
The Nolathane one (p/no 41039) I got from Pedders was red, and a perfect fit.
Are you sure yours is for the Oz rack not the UK one...
PostPosted: Sun Oct 12, 2008 10:57 pm
Got it from Karcraft when I got the rest of the bits. - I've pulled apart another rack but all the internals are different - differents sizes etc BUT the bush is a red neoprene with hex bore - I wonder :roll:
David L
Users browsing this forum: Bing [Bot] and 95 guests
