It is currently Fri Jul 18, 2025 2:32 pm
PostPosted: Sun May 16, 2004 11:07 pm
I am currently restoring a 1976 mini pickup and would like to know where i can buy the body coloured arch flares that lots of australian minis are fited with. In the uk similar archs with crome trim are avaliable but have visiable screw holes which make them look a little tacked on. Any ideas? :)
 Post subject: flares
PostPosted: Sun May 16, 2004 11:44 pm
Howdy,
www.ebay.com
Cars and auto; Accesories; mini
mick
PostPosted: Mon May 17, 2004 12:54 am
I would idealy like new flares, so does anyone know anywhere selling them?
PostPosted: Mon May 17, 2004 10:51 am
The flares you are referring to are the standard ones fitted to Aussie Minis such as the Clubman S and also the Cooper S. Instead of being screwed to the body, they are riveted to to guards underneath the chrome trim (so as not to be visible) and have a metal extension welded to the guards (hard to explain - the bit that you rivet to). The ones you are referring to are the group 2 arches (I think?) and they are basically the same thing, except mount differently.
The local guy here in Canberra sells them (www.classicmotoring.net.au), but I didn't think they were an Australian only part - should be able to order them from any reputably Mini parts supplier.
Anto.
PostPosted: Mon May 17, 2004 7:20 pm
Anto.
That sounds like what i am thinking of. Are these the ones on the cooper on the front page of ausmini.au? For some reason the link youhave given just comes up blank are you sure its correct?
Thanks
PostPosted: Mon May 17, 2004 7:31 pm
If you mean the ones that are on my clubman, which are the same as the roundie next too it (pretty sure anyways), then they are standard fitment on pretty much every (all?) Aussy clubmans after about 75 or so.
PostPosted: Mon May 17, 2004 8:03 pm
They were used only in Australia and South Africa.
Try http://www.miniauto.com.au/ , I think Ken has some. :wink:
PostPosted: Mon May 17, 2004 8:10 pm
yeh those are the ones. Over here in the UK nobody knows what they are or where to get them and ive never seen a car with them on. I like to be a little different.
so are they avaliable anywhere?
PostPosted: Mon May 17, 2004 8:13 pm
As I said above www.miniauto.com.au (in Qld had some). I'm not sure if new or remanufactured. Last car that had them fitted new here was in 1978.. :lol:
<edit> click his email link.
PostPosted: Mon May 17, 2004 8:23 pm
Sorry didnt spot that link. Ive e-mailed them so we'll see what they say.
Thanks
PostPosted: Mon May 17, 2004 8:25 pm
They aren't overly wide, so just a warning.
PostPosted: Mon May 17, 2004 8:28 pm
Note- they are mounted unlike any UK style flares- there are metal strips welded inside the arches, then these flares sit on this and are held on mainly by the chrome plastic strips.
Look good when fitted, but the plastic is thin and flimsy.
PostPosted: Mon May 17, 2004 9:32 pm
there are two kinds, the standered "s" ones, and theres a wide version 2. :)
PostPosted: Mon May 17, 2004 11:14 pm
I Think i understand what you mean. Is it sonething like the wood and pickett arches in the uk that dont have viable screw holes but screws that go up through the wing lip? :D
PostPosted: Tue May 18, 2004 12:09 am
Check out the flares I used at www.pbase.com/hanra/mini as far as i know these were just standard S flares in fibreglass. That i bought new from Mini Spares Centre, they did need some re-fibreglassing to make them fit perfectly. I wouldnt of thought that they would be so hard to come across over there!!!!!
