It is currently Sat Jul 19, 2025 2:26 am
PostPosted: Mon Oct 13, 2008 5:01 pm
would a rover bonnet and grill fit on an old round nose body.1 have a 1980 round nose mini i imported from nz .i crashed it and was wondering if i got an old round nose body could i use the bonet and grill of the 1980 mini as it is the same as the rover or jap imports :?
PostPosted: Mon Oct 13, 2008 5:30 pm
i know the grill sits up on the bonnet with the rover wheras the older aus minis had a complete seperate moustache not 100% sure but i know someone will know sorry i cant help.
Enjoy Chris ;)
PostPosted: Mon Oct 13, 2008 5:33 pm
Hinges are different on the later ones.
PostPosted: Mon Oct 13, 2008 6:07 pm
You might find the Rover bonnet is the same fittingwise as your 1980 UK/UnZud Mini, measure the hinge spacings to be sure. :wink:
The Rover spacing is the same as Oz Clubbies... :shock:
PostPosted: Mon Oct 13, 2008 6:52 pm
Some of the rover bonnets have brackets for the hinges in close like the Aussie bonnets ,Steve at brickworx had one on eday a while ago.
Cheers Pete
PostPosted: Wed Oct 15, 2008 11:00 am
easy enough to do.
i have rover fronts on both my minis.
bonnet needs hinges in a diferrent spot but with some careful measuring you can make some new ones and weld them on!
i have recently modified my delux to have a mk1 bonnet and grille on it instead of the rover ones i had on there!
it was easy you really shouldent have any problems, only big issue is the hinjes
anything else should be commmon sense.
any questions or want any pics let me know!
jamie
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
Users browsing this forum: No registered users and 23 guests
