superSeven wrote:
ok..
so I put a ventilation filter on the flywheel end ventilation.. and the one from the rocker cover I thought I'd connect to the carby... should I have a PCV in there or can I just connect it straight up to the carby?
im getting a lot of mayo under the oil cap so want to get it breathing as well as I can.. and i want to get the engine bay as tidy as possible.
thanks
tim.
The best way to ventilate the motor properly is to hook the breathers up properly and not to stick silly filters on the ends of the outlets so that they block up with crud after a few weeks. They are just underbonnet rice.
If you hook the breathers up properly the motor will breathe better and there will be less mayo under the oil cap.
