It is currently Sat Aug 09, 2025 10:00 pm
 Post subject: missing part on an sc12?
PostPosted: Tue Oct 21, 2008 11:11 am
am i missing a part around the pulley area on my sc12??
was just looking at pics of some and it looks like im missing a bit next to the pulley...
and where do i connect the wiring? :?
cheers James
'75 windowless van
~LOLA~
PostPosted: Tue Oct 21, 2008 2:22 pm
Forum Graffiti
Hehe, nowhere to connect the wiring when you're missing the clutch :P
Not exactly a bad thing, just means it will always be 'on' :wink:
PostPosted: Tue Oct 21, 2008 2:39 pm
ok so i'm missing the clutch eyy :(
are you still able to fit it to ben's kit with out it?
or would i be able to find a clutch for it some where?
'75 windowless van
~LOLA~
PostPosted: Tue Oct 21, 2008 6:33 pm
It has been modified to a single v belt pulley the clutch and original pulley has been removed.
The way that one is set up the pulley runs directly on the input shaft of the SC and may flog out the bearing / seal causes too much load on the shaft. The oringinal uses a separate bearing that the pulley mounts on and uses the clutch to lock it to the input shaft.
So it will not directly fit with one of my kits uses wrong pulley and the pulley may be in the wrong position.
4efte powered Clubman
supercharged 998 race car
PostPosted: Wed Oct 22, 2008 7:16 am
DAM :evil:
does anyone know where i mite be able to find one?
anyhelp appreciated!!
'75 windowless van
~LOLA~
PostPosted: Wed Oct 22, 2008 10:29 am
Forum Graffiti
You could always go for a little more boost :twisted:
http://cgi.ebay.com.au/103mm-Clutched-S ... .m20.l1116
PostPosted: Wed Oct 22, 2008 11:11 am
haha yeh i have seen them...
mite have to if i cant find a regular one :D
'75 windowless van
~LOLA~
PostPosted: Thu Oct 23, 2008 7:59 am
ok i've found one but how much do u think they are worth??
he said just make an offer..
$50??
'75 windowless van
~LOLA~
PostPosted: Thu Oct 23, 2008 6:09 pm
$50 for the complete sc or just the pulley
I would say $20-$30 for a secondhand pulley and clutch if they don't take it you can always go higher
PostPosted: Thu Oct 23, 2008 6:29 pm
Forum Graffiti
If it's $50 for the complete SC, I'll give you $100 and you can still keep the pulley :P :P
PostPosted: Fri Oct 24, 2008 7:54 am
hahaha nah just the pulley..
and he wants $80 for it and without the face plate.
mite just keep looking around but not having much luck at all :(
'75 windowless van
~LOLA~
Users browsing this forum: Bing [Bot] and 85 guests
