It is currently Mon Aug 04, 2025 10:29 am
 Post subject: How to remove trim glue
PostPosted: Tue Oct 28, 2008 3:19 pm
Hi guys,
I pulled off the dash, door trims, carpet and underlay from my 78 clubby. There is a lot of glue residue still coating the painted metal, not to mention a covering of hair from the underlay growing out of the firewall. (Is this what people mean by "hairy lime green"??) There are also various hairy papery bits stuck onto the doors behind the trims.
What solvent can I use to remove this crap? I want to give it all a coat of paint. If the dash rails look nice enough, I'll leave them exposed. Don't like the look of the vinyl dash.
I'm going to brush on the paint. Any tips for making minimizing brush marks?
-hg
PostPosted: Tue Oct 28, 2008 3:20 pm
Turpentine will soften and remove it, not in one go however. Wet it using a rag soaked in the turps and let it sit a while, and them wipe away as much as you can. The rest will follow as it is exposed to the turpentine.
PostPosted: Tue Oct 28, 2008 3:40 pm
I love this stuff
http://www.pascoes.com.au/products.php?which=117&level=6
- it just eats through sticky stuff with a few wipes, soak it in if it's thick and re-apply.
Better than the Orange Glo brand version (which is really slimy)
You can get it at Woolies
PostPosted: Tue Oct 28, 2008 4:21 pm
The Mini King
I often use eucalyptus or citranella,
