It is currently Mon Jul 28, 2025 8:12 am
 Post subject: a1456
PostPosted: Wed Oct 29, 2008 5:33 pm
A1456 this is the number on the head at the moment is this the standard head for a 998?
cheers TUCK3R
PostPosted: Wed Oct 29, 2008 5:47 pm
It's 12A1456, yeah it's for a stocko 998. :wink:
a 12G202 (1098) head is better, but the old 1456 can be ported out the same way, it's just more work (more metal to come out) to get to the same level.
PostPosted: Wed Oct 29, 2008 6:03 pm
am i better of going the 202 or stick with the one i have and port that?
PostPosted: Wed Oct 29, 2008 6:22 pm
A 202 is better to start with because ports are bigger and so are the inlet valves. Just bolting it on stock is worth around 3 or 4HP.
A 295 is better still, in stock form.. :lol:
PostPosted: Wed Oct 29, 2008 7:23 pm
ok thanks for the advice.
cheers TUCK3R
 Post subject: A Head
PostPosted: Wed Oct 29, 2008 8:16 pm
Doc...but if he ported and polished (shaped the combustion chamber) his existing head...and skimmed it to bring the compression up (maybe hardened seats)...would that be just as good :?:
 Post subject: Re: A Head
PostPosted: Wed Oct 29, 2008 8:53 pm
Not unless he fits bigger inlet valves, reshapes and deshrouds the chambers, decks it and enlarges the ports a lot.
Around 2x as much work as porting a 202 head, IMO. :wink:
PostPosted: Wed Oct 29, 2008 9:56 pm
Ohhh? do tell :!: ...so 202 is reasonably desirable for that reason alone 8) :D
PostPosted: Wed Oct 29, 2008 10:06 pm
It was a Cooper 997 head you know...should have Cooper tax applied!
PostPosted: Thu Oct 30, 2008 6:31 pm
shhhhhhhhhhhh tax is bad
Users browsing this forum: Bing [Bot] and 78 guests
