It is currently Tue Aug 19, 2025 7:42 pm
 Post subject: re-bore or hone?
PostPosted: Fri Oct 31, 2008 9:21 pm
How does one come to this decission?
I've recently purchased a 1275 for my rebuild that I'm told is +20thou. The bores look to be in pretty good condition with a very slight lip and previous hone markings still present.
I like the idea of keeping it at 1293 but reality is it will probably need a re-bore.
Is it just a matter of asking someone in the know to have a look and advise?
BC.
PostPosted: Fri Oct 31, 2008 9:25 pm
id go the bore, not much more and it'll give you a much better motor in the long run. do it once do it properly i say.
Aaron
PostPosted: Fri Oct 31, 2008 9:31 pm
You can see the wear at the top of ring travel, a hone won't remove that.
You will probably find a new set of rings for your old pistons are the wrong side of $100. They won't work well or last long with that wear there.
It needs a rebore and hone to 1310, then you will get nice straight round bores with the right piston clearance. :wink:
A set of +.040" Hypatec pistons and Hastings rings is only around $170.
UK `AE Hepolite' ones are dearer, but no better.
PostPosted: Fri Oct 31, 2008 9:38 pm
Did the GT block come with any other goodies?
Thanks guys. Sounds like a rebore is definitely the way to go.
appreciate the comments.
Think I'll go with a GR RE13 too :wink:
PostPosted: Fri Oct 31, 2008 10:25 pm
:) You can get +30 pistons so it will be a 1300cc (thats what mine is).
:roll: I know there is no subsitute for (in this case) cubic centremeters :D
PostPosted: Fri Oct 31, 2008 10:40 pm
unfortunately not mick... crank would've been nice!
Scott - so size really does matter?? :lol:
PostPosted: Fri Oct 31, 2008 10:44 pm
If it is already +20, will +30 be enough to clean it up? I'm no mechanic but as a machinist I would have thought +40 would be easier to achieve an that +30 would be a bit tight.
Mini K, 1310, Jet Red/Crystal White Roof, Rover Interior
75 Clubman
PostPosted: Fri Oct 31, 2008 11:05 pm
What crank do you need :?:
It has is place BC :wink:
If you are not worried about doing another rebuild on it you may as well go straight to +60
PostPosted: Fri Oct 31, 2008 11:41 pm
GT or mkII S would be nice!!
nah wanna keep this block for as long as possible - hence the question about honing v's reboring. If I was gunna go BIG I'd just rebuild the 1100s block that's already in the car.
PostPosted: Fri Oct 31, 2008 11:51 pm
BALLISTIC wrote:
will have a look see :)
PostPosted: Sat Nov 01, 2008 6:00 am
That block might clean up at +.030" but I wouldn't bet on it. Safer to go to +.040", IMO.
Still are 4 rebores available after 1310, (ignoring the 74.7mm maybe possible size). :lol:
PostPosted: Sat Nov 01, 2008 3:04 pm
Just check the block isn`t sleaved first,,, :-)
PostPosted: Thu Nov 06, 2008 7:23 am
how would I do that? It doesn't look like it has been .... :?
Users browsing this forum: No registered users and 144 guests
