It is currently Wed Aug 06, 2025 10:57 am
PostPosted: Thu Nov 13, 2008 9:02 am
Do these mounts come with the captive/welded nuts on them :?: :| I have a feeling that you will be going past my place (sort of) later in the week to return these mounts :?:
PostPosted: Thu Nov 13, 2008 9:14 am
Last time, I got 2 bits of 8mm steel bar, 150mm long, ground a point on one end to make em pry bars.
By working these in you can eventually get it so one bolt will fit. Do the nut up pretty tight, then use the pry bar to align the other hole. :wink:
Or Phillips head screw drivers - I've a couple of big ones that get use more as pry bars than as screw drivers :roll:
David L
PostPosted: Mon Nov 17, 2008 9:01 pm
Hang on , they look different again to some cheap and nasty mounts I've seen , the ones I was thinking of were basically the same as the originals except they would have been perfect for putting a manual engine in an auto subframe .
PostPosted: Mon Nov 17, 2008 9:02 pm
There is another with captive nuts in, it fits even worse... :evil:
And the threads are cheese, they strip real easy.
PostPosted: Mon Nov 17, 2008 9:06 pm
Can't remember if the nuts were captive or not but they were considerably thicker than original and a real pain in the #$@
PostPosted: Mon Nov 17, 2008 9:11 pm
That's them.
POS mounts... :lol:
PostPosted: Mon Nov 17, 2008 10:28 pm
Hmmmm- the one on the right looks like the pair I just got from a reputable Mini Dealer. So what is the answer ? - where do we get the good ones from?
David L
PostPosted: Tue Nov 18, 2008 6:10 am
You want genuine ROVER ones. Karcraft stocks them, note they are over 2x the price...
PostPosted: Tue Nov 18, 2008 4:33 pm
Hmmmm, could the dodgy thick ones come in handy to fit a manual motor into a matic subframe? :?
PostPosted: Tue Nov 18, 2008 6:13 pm
Are you sure the "5mm" thicker ones are not Austin 1300 ones? -
they are exactly the same but thicker, puting mini ones in a 1300 results in the rhs pot joint coming apart while reversing into carparks on an angle - dont ask how long it took me to figure that out!
PostPosted: Tue Nov 18, 2008 6:21 pm
Morris (no Austins here) 1300 or 1100 ones are different, here anyway, the clutch end one is 2 flat plates, not wave shaped like Mini ones.
The rad end has a different setup to a Mini- 2 mounts on the engine front plate, like a Morrie 1000.
PostPosted: Tue Nov 18, 2008 7:46 pm
I thought they were the early design mounts from 850s etc? I had always assumed they had been superseded by the wavy ones...I suppose that's why they were still available new for so many years then...
PostPosted: Tue Nov 18, 2008 7:51 pm
1100 ones are no good in a Mini, they are not stiff enough laterally and the engine moves more to and for when you nail it or back off..
PostPosted: Wed Nov 19, 2008 6:47 pm
Got some genuine Rover mounts today and compared them to the OEM ones from another Mini Dealer - sorry the pics are blurry - flash was playing up. Genuine has the yellow dot
Easy to see the misalignment of the holes in the second one - and that is NOT parallax.
David L
PostPosted: Wed Nov 19, 2008 6:54 pm
There's a lot of rubber to be saved if they sqeeze the plates up as they do in the cheap ones, I wonder if that is their motive?
