It is currently Thu Jul 31, 2025 8:57 am
 Post subject: Assembly point
PostPosted: Thu Nov 20, 2008 12:07 pm
Do you put the primary gear oil seal in the housing before assembly of the box to the block or after?
David L
PostPosted: Thu Nov 20, 2008 12:47 pm
I've done it both ways. It's a little harder to make sure it doesn't get damaged when you assemble the housing complete with the seal, but you can really make sure it's seated nicely. I've never had it leak either way...
PostPosted: Thu Nov 20, 2008 12:51 pm
I always put it in the housing, then put the housing over the primary gear. I have a roll of 2" wide electrical tape that I wrap around the primary gear to stop it damaging the seal, then I unwrap the tape when it's all bolted up
PostPosted: Thu Nov 20, 2008 1:02 pm
ditto
PostPosted: Thu Nov 20, 2008 2:15 pm
So are you putting the box and block together then adding the housing? I know it sounds a dumb question but the inference from the Mini Expert is that you bolt up the housing to the gear box off before assembley to block.
David L
PostPosted: Thu Nov 20, 2008 2:20 pm
if that's the bit about working out the right thickness for the idler gear washers, what they don't say is that you work out the end float, then take the cover off the box, assemble the motor & gearbox, then put the cover on again
PostPosted: Thu Nov 20, 2008 2:31 pm
Ta
David L
Users browsing this forum: Bing [Bot] and 87 guests
