It is currently Sat Jul 19, 2025 12:22 am
 Post subject: Flywheel drive straps
PostPosted: Sat Nov 22, 2008 9:50 pm
How much can you build these up safely with washers? I have to fill about a third of and inch (0.304") to get them level
David L
PostPosted: Sat Nov 22, 2008 10:35 pm
as much as it takes to get em flat....should be built up with weld though :D
PostPosted: Sun Nov 23, 2008 6:09 am
Noooooooooooooooo...!!!!!!!!!!!
Make 3 new thick spacers on a lathe...... do it properly.
Hole should be 3/8" diameter so they fit snug on the bolts.
PostPosted: Sun Nov 23, 2008 2:01 pm
Welding a cast iron flywheel :shock: if or when it lets go it'll be spinning at thousands of rpm right in between your legs :shock:
PostPosted: Sun Nov 23, 2008 2:25 pm
Yeah...I must have had a brain fart and was thinking about steel flywheels :roll:
