It is currently Fri Jul 18, 2025 11:21 am
PostPosted: Thu Feb 10, 2005 8:41 pm
Will i need to make a box into my firewall (similar to a weber box) to fit the carby inlet piping? Any help would be appreciated....
I have the turbo sitting over my clutch as is so I know I dont have to cut the firewall down the bottom and across the crossmember, but above it????
68matic: "i havent seen much head in my life "
PostPosted: Thu Feb 10, 2005 8:48 pm
You won't have to if you have a metro turbo plenum.
PostPosted: Thu Feb 10, 2005 9:47 pm
See kazjim's pics, that's what he has- there's a bit of room. 8)
PostPosted: Thu Feb 10, 2005 9:56 pm
cheers kev. will do
PostPosted: Fri Feb 11, 2005 7:52 pm
Not a Lot of room, but I'm using a standard 1275 cast-iron inlet (separated from an exhaust)
I think its a bit better flowing than the metro one..... definitely larger runners and looks to be more volume too.....
J
PostPosted: Sat Feb 12, 2005 4:09 pm
i thin its going to be a REAL tight sqeezeas I have just set up a HIF44 (non turbo) on a mini spares manifold...
Might have to make a custom plenum.... There is only like 2 inches sace behind the inlet... :(
PostPosted: Sat Feb 12, 2005 7:23 pm
Metro turbo plenum is pretty thin, anyhow it's narrow- should fit in the firewall hole without cutting.
:idea: Try a Clubbie blanking plate behind the hole, they are recessed a bit. :wink:
PostPosted: Sat Feb 12, 2005 9:44 pm
i foun a guy in the campbeltown area with a metro plenum.... is $50 bucks steep??? He wanted 100 but i thought he was dreaming....
PostPosted: Sat Feb 12, 2005 10:00 pm
I think a 50 is fair. Not that common over here. :lol:
PostPosted: Wed Mar 09, 2005 9:02 am
here is a pic of the inside of my trbo box
the big tube at the top is the brace which is welded to the original chassis cross member. but this shoudl give you some sort of idea as to the size
100% Pure A Series Turbo
PostPosted: Wed Mar 09, 2005 2:25 pm
damn... i wont be needing any of that anymore... i'm using Screaming performace in the gong to do the work and they have the parts to convert my weber to turbo.... apparently tey have done quite a number of turbo setups using webers before.... :lol:
I am getting new manifolds made so if anyone is interested, pm me for prices on the old ones... :D
New ones are all stainless, will keep the engine steadies in place and he is making a custom cooler for the front grill... well its replacing the front grill... :shock: same shape and height and should only stick out a little bit :D
