It is currently Sun Aug 03, 2025 7:36 pm
 Post subject: cam followers
PostPosted: Tue Nov 25, 2008 8:09 pm
buying new cam followers is there any I should avoid
PostPosted: Tue Nov 25, 2008 8:14 pm
High heel ninja
According to Graham Russell, most of the new ones are rubbish, he says if you can find some old 850 ones grab em & use them.
Doogie
PostPosted: Tue Nov 25, 2008 8:38 pm
GR says the Isky pattern ones are OK, and the Minispares lightened ones. :wink:
PostPosted: Wed Nov 26, 2008 11:09 am
where can u get the push rods for the 998 /1100 engine I have seen plenty of 1275 pushrods avalible BBut no ones for the smaller engines. Is ther Any difference or can i use the 1275 Push rods.
PostPosted: Wed Nov 26, 2008 11:52 am
Give Ash some flowers Nick .
You can't use 1275 push rods in a small bore. The block is taller on a big bore (so needs longer push rods). They are not interchangeable.
PostPosted: Wed Nov 26, 2008 1:47 pm
I'll swap you a set of small bore rods for a set of 1275 push rods
David L
PostPosted: Wed Nov 26, 2008 1:58 pm
I hear there are some modified Ford ones you can fit...
PostPosted: Wed Nov 26, 2008 3:26 pm
Push rods or cam followers?? If cam followers, you need to rebore the follower holes in the block.... no good!
Minispares Isky Type C-AEG580 is what you want: http://www.minispares.com/Product.aspx?pid=33105
PostPosted: Wed Nov 26, 2008 7:27 pm
Do you want new or sh? If sh, how many do you want?
Steve
PostPosted: Thu Nov 27, 2008 1:15 pm
Well i dont Need any ATM but further down the track i might need some sepending how the condition of them are, Once the engine is getting pulled down for surgery Id say in about 2 months or longer we will bepreping for paint within the next month. Just taking my time making sure things are done nicely. i know when fitting a New cam you should always replace the Followere but im unsure about the push rods.
PostPosted: Thu Nov 27, 2008 6:38 pm
No need to change pushrods, unless they are bent. Roll them on a flat machined surface to find out.
 Post subject: 8 for 8
PostPosted: Thu Nov 27, 2008 7:24 pm
Doogie
Now thats interesting...this may be the only redeeming feature to be found in the humble 848cc?? :D
PostPosted: Thu Nov 27, 2008 7:57 pm
Don't get your hopes up Mick- 850 ones were nothing special, they used to wear and chip just like all the others always did.. eventually.
They were all just chill cast iron. I'd never use old s/h ones on a fresh cam.
Now, OTOH if you DO have some NOS 1962 850 ones.. use em.:lol:
Users browsing this forum: Bing [Bot] and 84 guests
