It is currently Wed Jul 23, 2025 9:34 am
PostPosted: Fri Dec 05, 2008 1:01 pm
I know it's a simple one, but I can honestly say with all the cars I have owned, I have never had one long enough to need change the brake pads.
Is there any person with some spare time on here willing to put up a How-To on brake pad changes ?
I will be doing it this arvo either way, I have a guide already, but it might be handy for others in the future.
I don't want to do it myself...as I might end up doing it complete wrong :)
PostPosted: Fri Dec 05, 2008 2:36 pm
High heel ninja
Loosen wheel nuts,
Jack up
Put jack stands under car
Lower jack onto jack stands
Remove wheels,
Remove pad pins
Using two large screwdrivers slide caliper pistons back into calipers
Remove old pads
Fit new pads, transfering any rattle shims from the old pads
Refit pins
Refit wheels
Tighten wheel nuts
Lower back onto ground
Recheck wheel nuts
Pump brake pedal to repressure the system
Check brake fluid level in master cylinder
Drive away.
Doogie
PostPosted: Fri Dec 05, 2008 2:47 pm
What he said ^^^
Remove and replace ONE pad at a time- if you take both out together, one piston can get moved out by the fluid when you are pushing the other back in.
Inspect those split pins, if any doubt fit NEW ones. And bend both sides back. I lost a pad recently whilst driving... = NO brakes. Scary stuff. :shock:
Users browsing this forum: Steam and 79 guests
