It is currently Mon Jul 28, 2025 10:16 am
 Post subject: fresh air heater pipe
PostPosted: Tue Dec 09, 2008 2:07 pm
does anybody know where i can buy the fresh air heater plastic pipe from in melbourne ? (the big one thats about 83mm in dia.) without paying big money for it from a mini garage
PostPosted: Tue Dec 09, 2008 3:54 pm
Purple Pig - few branches in various suburbs
PostPosted: Tue Dec 09, 2008 4:02 pm
how about the tin foil & paper one as used in earlier cars? (Cooper S)
PostPosted: Tue Dec 09, 2008 4:22 pm
it is aluminium and paper :) and good luck
have been told hard to get and not cheap.also the plastic is more resilient(can stand a kicking)
purple pig good place not overly expensive.
PostPosted: Tue Dec 09, 2008 5:01 pm
Vas ist das "Purple Pig"
PostPosted: Tue Dec 09, 2008 5:56 pm
Purple pig
is trade supplyer sell all types pipe matting hose fittings and stuff.
PostPosted: Tue Dec 09, 2008 6:58 pm
This space for rent
I went looking for this stuff last winter and couldn't find it anywhere. Instead, I used PC CPU fan ducting and a 80mm case fan, totalling around $30 online:
This is a neat fit inside the heater outlet and firewall inlet, so I used a little tape to hold it in place. Works brilliantly, and converts the old fresh-air heater into fan-forced 8)
PostPosted: Tue Dec 09, 2008 7:00 pm
I did similar but used an Attwood 3" bilge blower from Bias Boating. Blows more air but makes more NOISE!!
PostPosted: Tue Dec 09, 2008 8:51 pm
Got to hand it to you guys, necessity truly is the mother of invention.
Brian
PostPosted: Tue Dec 09, 2008 9:04 pm
Have a look for rangehood ducting in Bunnings. There were a few different diameters avail last time I looked, and it's light, flexible, aluminium and ribbed, looks almost-sort-of original...
Wasn't too expensive either; $25ish irrc.
1958 Morris Minor 1000 - "Nigel"
PostPosted: Tue Dec 09, 2008 9:06 pm
Here's mine, the blower is the white thing- it just sits in the ducting flange on the bulkhead.
PostPosted: Tue Dec 09, 2008 9:11 pm
This space for rent
Smallest size Bunnings stock is 100mm.. Believe me, I checked there, it's the first thing I thought of ;)
PostPosted: Wed Dec 10, 2008 9:49 am
nah, I want the smaller stuff (maybe 50mm) that goes from the S heater windscreen outlets to the windscreen duct
tin foil on the inside, black paper on the outside
PostPosted: Wed Dec 10, 2008 12:06 pm
I took the opportunity and dropped into the Purple Pig today (that's a pretty dodgy name btw...) for the small windscreen demister duct stuff. I have some of the original stuff (which is more like washing machine drain hose than anything else) but it's not really up to scratch.
The modern equivalent is nearly identical, but 300 times better quality. It's flexible, durable and hi quality all around. A bit expensive at 17 dollars per meter however...but it's a done deal....
I looked at the other ducting available, the duct you are after for the inlet is very similar to the original, and is available in 60 to 600 mm diameters. Forgot to get a price unfortunately.....
PostPosted: Wed Dec 10, 2008 12:14 pm
Mick - did you get a catalogue number for that? and how much do you need for the two ducts?
David L
