floss wrote:
As mentioned before it happened on a 40 odd degree day back in april and I think that is the main reason for the over heating.
a hot day isn't a reason for overheating - it may be a catalyst, but it's not a reason...
I drive my cooper s every day no matter how hot it gets, and it's never over 2/3rds of the way up the gauge when sitting at the lights etc. then as soon as I get moving, it drops down to well below half
I sat it idling one day and let it heat up and used a remote infra red thermometer thingy and measured the temperature all over the motor and nothing was over 80 degrees (extractors are at 242 degrees C!)
my engine is a bit gruntier than standard, and I've got a completely stock cooling system
floss wrote:
Just checking what people think might be the problem if not so I can check while the motor is out and easy to get to.
honestly, there are too many reasons for overheating to list - and any number of them could be the cause - so I go back to what I said, make everything perfect - they didn't overheat from the factory, it's only years of neglect that get them into that state
floss wrote:
I have had the rad flushed out and cleaned by a rad place. I will order a new thermostat and hoses anyway as it seems like good sense.
it is good sense - but get a new water pump too, and flush the block out with water.
Block up the heater outlet, remove the thermostat, put the thermostat housing back on and clamp a high pressure garden hose nozzle into the top radiator hose. Turn on the tap and let water blast through the motor until clean water is coming out of the bottom radiator hose, then clamp the garden hose into the bottom radiator hose, and do the same thing - keep doing it until the water runs out clean both ways...
take the heater out of your car and do the same thing, if it's a clubby one, it's a 5 minute job to remove the heater core and give it a good shake to loosen up any junk and get it out of there
floss wrote:
Do you guys run the 74 degree, 84 degree or something else I don't even know about. I read ( when searching on this subject ) that some people have a summer and winter thermostat and change them. Do you guys do that?
I've never needed to run anything other than an 82 degree thermostat, but a hotter (90?) one in winter might be a good idea because my car does run too cold at times
floss wrote:
I really didn't want to do the head gasket as I was afraid I would just stuff it up to be honest. It seems like these are prone to stuff up if not done perfectly and mine SEEMS to be fine so what do you all think? I guess it comes down to that old thing of where do you stop on a rebuild.
follow the workshop manual and it's pretty hard to make a mistake - most important bit after properly torquing the studs is that the mating surfaces (head, block, manifold) must be utterly spotless - to the point where you can wipe them with a tissue and it comes off clean
if you stuff it up, then you do it again, and you don't make the same mistake - simple
did I tell you that I won a
trophy?
