It is currently Sun Aug 17, 2025 9:20 pm
 Post subject: boss kit
PostPosted: Sat Dec 27, 2008 3:47 pm
where did you get yours? and what sort do you get?
anyone know one to suit 77 clubman
PostPosted: Sat Dec 27, 2008 6:49 pm
All Oz Minis have the same spline on the steering column shaft.
But, aftermarket wheels are not all the same. I have a SAAS hub and a MotaLita one, they each fit their own brand wheels.
I believe an AutoTechnica hub has a few different hole patterns in it, to suit various wheels.
I would not buy a wheel without sussing out a hub to suit it first. :wink:
 Post subject: Boss Kits
PostPosted: Sat Dec 27, 2008 7:51 pm
I have found some Mazda older cars had the same spilne config as a Mini. All you will need is machine the base to fit over steering column cover. I have done a couple like that on my lathe. Cheaper than buying one for "A Mini"
"Let us remove your "SHORTS"
PostPosted: Sat Dec 27, 2008 7:58 pm
I believe some Volvo ones are the same too. Dunno which model... but Lillee runs one. :wink:
Users browsing this forum: Sahig131 and 329 guests
