It is currently Thu Jul 31, 2025 6:30 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Dec 31, 2008 12:41 pm
Mick wrote:
To narrow it down, I believe it will be found in the 6 inches of drain channel between the passenger bonnet hinge and the passenger window spray nozzle.
Very easy to miss as they are light stmapings (perhaps by hand and all at once in a jig, so little penetration) and are easily filled in by the primer/fillerand paint
On mine the number is midway between the bonnet hinge and the end of the channel where it joins the mudguard on the passenger side. The number is viewed from the front of the car.
Simon - I can understand your reluctance to remove paint so I guess it comes back to how inquisitive you are. This area is usually out of sight and originally had a rubber strip across the channel to absorb vibration from the trailing edge of the bonnet (part no. HYA3925 according to PUB 1056M) so if you carefully removed the paint, took a photo and touched up again I'm guessing no-one would know the difference. If I were in your shoes I would do it simply to satisfy my curiosity. Then again, you might find something you didn't want to.
 Post subject: Yep
PostPosted: Wed Dec 31, 2008 12:45 pm
winabbey wrote:
I believe originally had a rubber strip across the channel to absorb vibration from the trailing edge of the bonnet (confirm anyone?)
Confirmed.
 Post subject: Re: Yep
PostPosted: Wed Dec 31, 2008 1:07 pm
9YaTaH wrote:
Confirmed.
Thanks. I should've checked my parts book before posting. I've now updated my original post with the part number.
PostPosted: Wed Dec 31, 2008 2:26 pm
I have a mid 1970's Mini K and the number is stamped on the fire wall above the clutch master cylinder. Nothing in the gutter on this one.
The S of the same vintage may also have it above the master cylinder and not in the gutter. Check there before you remove paint.
My 1969 Mk2 has it in the gutter.
PostPosted: Wed Dec 31, 2008 3:08 pm
yeah, mine has it on the firewall near the MC's, but I gather it was stamped in both places - maybe :?
PostPosted: Wed Dec 31, 2008 3:10 pm
I'm pretty sure you'll find it's one or the other - I think (from the numbers I've collected) that they swapped the stamping position sometime around Feb/March 1970.
PostPosted: Wed Dec 31, 2008 3:28 pm
I'm sure I won't find anything I don't want to find.... and there is plenty of paint missing already, so it doesn't worry me too much - we'll see how enthused I get
d'oh - mine is July! :lol: the S's I've seen (several lately!) around the July '70 mark have had them on the firewall - no verification of the gutter - bloody inconsistent sausage makers BMC were
so it was the series of same number as on the firewall - IE the body shell number, starting at 1
PostPosted: Wed Dec 31, 2008 3:57 pm
Yep, ours is a July plated car as well - and has the number on the bulkhead, NOT on the drain channel.
That's what I'm lead to believe - and the numbers I've collected back this up - the 500-ish difference between the body and chassis (rad cowl) numbers is maintained whether the body number is on the drain channel or the bulkhead.
PostPosted: Wed Dec 31, 2008 4:44 pm
Mine with numbers in the gutter is a 10/1970 MK II S. Assuming the date is correct it challenges some of the theories about the timing of the change from gutter to bulkhead.
PostPosted: Wed Dec 31, 2008 5:04 pm
Guess your car again goes to show that there were no hard and fast rules regarding what 'they' did when they were putting Minis together :)
Just as a test of the numbers I have collected - is your cars' radiator shroud number somewhere in the 2500 - 2550 range, winabbey?
PostPosted: Wed Dec 31, 2008 5:16 pm
YG2S4 2668
Another VMCI member has an ex-NSW Police 10/1970 MK II S with a body number close to mine and the same original colour (Kelp Beige). I'm guessing a batch of cars were built to SPO 41 (reversing lights, handbrake indicator, two-speed wipers, tacho, engine mods, etc.) and went down the production line together.
PostPosted: Wed Dec 31, 2008 5:31 pm
I have often wondered with little things like that (similar with the 850's) whether the person who stamped the numbers (as an example) went on holidays soon after the location was changed and whoever took over from him didn't know there was a change . Might have taken a few weeks for someone to pull him aside and say the stamping location has been changed 9or in the case of the 850's they've used the wrong container of engines and the numbers are running backwards for 5,000 cars ...) .
PostPosted: Wed Dec 31, 2008 5:48 pm
YG2S4 2668
Another VMCI member has an ex-NSW Police 10/1970 MK II S with a body number close to mine and the same original colour (Kelp Beige). I'm guessing a batch of cars were built to SPO 27 (reversing lights, handbrake indicator, two-speed wipers, tacho, engine mods, etc.) and went down the production line together.
Aah - yep, I guess being a police car could explain things. . .by my list, I would have expected 2668 to be a November or possibly even a December plated car. . .possibly they yanked a batch of shells off the 'normal' production line to do the police mods to them, placing them out of order. . .
PostPosted: Wed Dec 31, 2008 5:51 pm
Location: Burpengary,Brisbane Nth(the better side of Bribane)
One other thing , how many lines were there and how many different people did it ? I can't imagine only one bloke 24 hrs a 7 days a week stamping them :?
PostPosted: Wed Dec 31, 2008 5:53 pm
Well, I certainly know for a fact that they were using some really dodgy trainees when they stamped the bulkhead number on our Mk2 S. . .have a look at it!!
These numbers were under the factory colour code stickers (you can see the outline of there the stickers were), so they are certainly original!
Users browsing this forum: Bing [Bot] and 83 guests
