It is currently Fri Jul 25, 2025 1:05 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Dec 31, 2008 11:01 am
will the 500 ml cover the whole car? and how can it be applied? what other products do i need to apply to the surface before applying?
that should keep someone busy for a while :)
thanks
PostPosted: Wed Dec 31, 2008 11:14 am
I was doing RHF panel and lower beaver ( hehehehe) panel, soz always giggle there, and some inner guard and used about 1/2 the bottle.
i apply it with a 25ml varnish brush ( cheaper and only use once)
This stuff smells bad so shoodn't be used in an enclosed cupboard
as to other products it depends on if you are painting now or later.
NOW: spray your etch primer straight on, after RC is dry, then apply fav color
LATER: I spray cheap/aresol primer on it when dry, but not a heavy coat of primer, just enuf to cover it.
My father left this stuff exposed on the trailer outside in the weather and it survived quite well surprisingly.
- 1962 Beige Delight club car, Rebuilding.
- Motorkana Special
- Minor Mishap, 1958 Morris Minor
-- Last ever Tea Lady at Longbridge--
PostPosted: Wed Dec 31, 2008 8:43 pm
leighton, I thought 42 was the answer! What was the question?
 Post subject: Stop rust forming
PostPosted: Sun Jan 04, 2009 10:42 am
I remember and old spray painter friend of mine, He use to Rub the sanding block on an ordinary bar of soap while sanding a bare matal panel and then just wipe panel with a chamois. Stays nice and rust free for ages. Unless you park the vehicle near the ocen for ther view !
"Let us remove your "SHORTS"
