It is currently Tue Jul 29, 2025 3:03 pm
 Post subject: leaky fuel cap
PostPosted: Wed Dec 31, 2008 9:01 pm
Location: Burpengary,Brisbane Nth(the better side of Bribane)
One of my fuel caps leak so do I just replace the cork gasket or the whole cap. If just the gasket how thick do they start out and is just plain gasket cork ?
 Post subject: Re: leaky fuel cap
PostPosted: Thu Jan 01, 2009 8:26 am
A rubber sheet impervious to fuel is better....try and get a thickness that will give you a good seal.
PostPosted: Thu Jan 01, 2009 9:52 am
Go to a boat parts place like Bias Boating or Whitworths, a neoprene rubber seal for a cruisetank is a perfect fit. :D
Cork gaskets get torn up if there are any burrs at all on your filler neck. :x
PostPosted: Thu Jan 01, 2009 12:02 pm
Thanks guys :)
PostPosted: Thu Jan 01, 2009 12:18 pm
I tried all sorts of different seals, and eventually gave up and I now have a pair of cheapie brand ones that don't leak a bit - first time ever I can fill the tanks right to the neck without losing any!
might have to check out a boat shop when I do my resto Kev ;)
Users browsing this forum: fuzzy-hair-man and 117 guests
