Flute wrote:
Vicroads may not, but don't forget the Police CAN and probably WILL check the car for roadworthiness. You will be obvious without plates on and a permit does not give you permission to drive an unroadworthy car! The permit assumes the car IS roadworthy and is on its way to get the certificate OR repairs have been carried out and it is being tested. If you are driving a car with bald tyres, no brakes or no lights, even with a permit you will be booked and taken off the road.
Actually the Police can inspect
any car for roadworthiness, registered or not. If the car is unsafe due to bald tyres or no lights or something obvious like that, yes you will run into trouble. The fact that the car is on a permit just marks you out as more of a target.
When I drive a car on a permit I always type up the reason I am driving the vehicle with the destination address, signed and dated, and carry this with me. That way if I am pulled over I have something to show the officer to legitimise the trip. For example I had to drive my import Corona Coupe from home to Taylor's Lakes to have it measured up for the custom front seatbelts prior to submitting it for an engineers certificate. Technically with Japanese belts still fitted it was "unroadworthy", but this was the only way I could have the correct belts manufactured.
BTW: Shannons will insure you on a UVP if you ask them nicely, but strictly within the conditions of the permit.
