crisonic wrote:
Roumours continue regarding the changing of used S's back to Mini K and flogging off the S parts for better prices than the whole car!!!!! Then mooving the car on as a MIni K.
Word is that this happend to a number of S's originally owned by NSW police
I know of two MiniKs with bodies that have all the correct S bits on them. Fuel pump breather grommet: correct spot welded tabs for the fuel breather pipes : correct strap mounting for RH fuel tank: numbers on the rain channel and the radiator shroud were both there but there has been an attempt to remove them. All the other identifying bits were there but these could have been added at some stage although they dont look as if they have. Both the cars I know of have drilled holes where clearly a sun shade had been fitted
Is this fact or fiction or just another story to add to the Mini lore?
Do you still have access to these cars? If so there are a number of other things you can check in addition to the sun screen holes which would add weight to them being ex-NSW Police Cooper S:
1. Hole (usually patched) in the middle of the roof where the antenna was installed - can usually feel the patch through the headlining between the B pillars.
2. Reversing lights, comprising switch in place of gearbox reverse detent and modified rear turn indicator bulb assemblies to accept two wires.
3. Two speed wipers (a different wiring loom was used which included wires for wipers and reversing lights).
4. Bland original body colour (grey, white, beige).
5. Two small dents inside the top edge of drivers door resulting from Wibroc mirror mounting grub screws.
6. Two holes at left end of parcel shelf where brass Car ID tag was screwed.
7. Possibly holes in leading edge of front subframe where sumpguard was mounted.
8. Extra holes in drivers side inner guard where siren was mounted.
9. Three holes in triangular shape under passenger parcel shelf where AWA Carphone two-way radio bracket was installed.
10. Extra hole in handbrake mounting bracket to accomodate warning light switch (assuming switch itself is not present) and warning light on top right of oval instrument facia.
I haven't listed other modifications such as lowered seat frames and engine changes as these are easily added/removed. Of course holes can also be 'added' but the more holes in the areas I have listed adds more weight to an ex-Police vehicle claim. Unless you have documentation such as the vehicle handbook showing all the right numbers and NSW Police as original owners then you will never be 100% sure of its origin.
John Smidt (Mini King) is already on record (TME Police Mini issue) as having converted many ex-NSW Police Cooper S's to Mini K's.
