It is currently Fri Jul 18, 2025 12:30 pm
Post new topic Reply to topic  [ 68 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Fri Jan 09, 2009 4:29 pm
someone was suggesting that you`re not limited to engine choice,,,well,,, the truth is that "IF" you`re after a front engine/front wheel drive mini using a motorbike engine then the Yammy R! is about the only one the fits (with any room & without making a whole pipe of poo-poo fabing up stuff to make room for it)
The R1 bike power unit has it`s gearbox "up-ended" for want of a better decription, the gear box shafts are ontop of each other instead ofone behind the other as in conventional bike engines,,, so therfor the R1 is basically the shortest bike motor you can get in the 1000cc or bigger capacity.
My little R1 powered hill climb special was meant to be the test bed for an R1 powered mini but i`m so happy with it the way it is that i`m not going to bother adding all that weight that a road mini body will create
PostPosted: Fri Jan 09, 2009 7:16 pm
but what if someone from NSW was to offer you a whole bunch of money Matt? ;)
PostPosted: Fri Jan 09, 2009 7:48 pm
Hmmmm, I have a cunning plan...
PostPosted: Fri Jan 09, 2009 8:02 pm
"What now Baldrick?" :shock:
PostPosted: Sat Jan 10, 2009 12:45 pm
Could probably fit two of them in side by side for a harley V4.
Might need to cut some very big holes for air cooling and would need some hefty chain...
PostPosted: Sat Jan 10, 2009 1:29 pm
I reckon this would fit
http://www.rotecradialengines.com/0RotecR2800/R2800.htm
PostPosted: Sat Jan 10, 2009 1:37 pm
Thought of that already:
http://www.ausmini.com/forums/viewtopic.php?t=19598&highlight=
PostPosted: Sat Jan 10, 2009 2:00 pm
I always thought that a conversion was done to improve and advance the car not to lumber it with a dud engine
PostPosted: Sat Jan 10, 2009 8:15 pm
Ahh yes Harley Davidson, "Yesterdays Technology at Tomorrows Prices"!!!
PostPosted: Sat Jan 10, 2009 9:31 pm
Pumping sh!t like no other sh!t pump can pump sh!t.
PostPosted: Sat Jan 10, 2009 10:46 pm
Bit of a tangent but are their any V4 engines around?
PostPosted: Sat Jan 10, 2009 10:53 pm
Lancia and Ford.
PostPosted: Sun Jan 11, 2009 10:14 am
Honda and Ducati (maybe?).
PostPosted: Sun Jan 11, 2009 12:59 pm
Someone was doing a 800 honda V4 into the front of a mini.
I think it was on here ages ago...
PostPosted: Sun Jan 11, 2009 4:08 pm
must have gone well then :P
