It is currently Sat Aug 16, 2025 7:45 pm
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sat Jan 10, 2009 11:43 am
sports850 wrote:
hey look great Simon , simple question though , do LED's need to be set a certain way for the polarity of the power or are they like a regular bulb which will work with an alternator or a generator ?
LEDs are Light Emitting Diodes. This means that current will only flow one way through the diode and in doing so emit light. The LED will have a flat on one side which indicates the cathode lead which needs to be connected to negative battery polarity (earth for negatively earthed cars). I fconnected in reverse, no current flows and no light is emitted. You also need to limit the current flow through each LED by using a resistor in series. If not it will emit light briefly before it catches Lucas disease. Most LEDs operate in the range of 15 to 50 Ma. Resistors in the range of 1KOhm to 330Ohm at 1/4 watt will accomplish that.
PostPosted: Sat Jan 10, 2009 3:58 pm
Give Ash some flowers Nick .
So does that mean it will work on my positive earth car or not? :?
PostPosted: Sat Jan 10, 2009 4:36 pm
Sure will but you need to reverse the diode polarity. This time the anode (the other lead) goes to earth if its a positive earthed car.
PostPosted: Sat Jan 10, 2009 4:38 pm
Righto, sweet. Thanks for that 8)
PostPosted: Sat Jan 10, 2009 7:08 pm
Put me down for 2 sets please, Simon. 8)
PostPosted: Sat Jan 10, 2009 7:58 pm
good question! LED's do have polarity, the LEDs would need to be soldered into the board backwards, a simple matter of turning them around the other way
PostPosted: Sun Jan 11, 2009 9:40 am
Wouldn't you just hook the unit it up the other way round?
David L
PostPosted: Sun Jan 11, 2009 11:58 am
no, there's a common earth for the parkers and the indicators...
PostPosted: Mon Jan 12, 2009 2:16 pm
In that case then one set of positive earth when you get around to it please Simon .
PostPosted: Mon Jan 12, 2009 3:47 pm
if/when you do them im keen for a set
PostPosted: Mon Jan 12, 2009 4:19 pm
thanks everyone, I'll keep you posted
PostPosted: Mon Jan 12, 2009 9:26 pm
my order 4 Please Simon
PostPosted: Tue Jan 13, 2009 8:51 pm
ill take a pair, or a diagram and list of parts
do you have a rough price set yet?
1969 Blue Mini K, 1330cc, Weber 45, polished aluminum roll cage, Race seats, 4 point harness, full rewire incorporating 8 fuses, 6 relays and new headlights :) just needs tyres front shocks and a windscreen til re-register
PostPosted: Tue Jan 13, 2009 10:27 pm
I haven't set a price - when I do I'll let everyone know before you need to commit
I need to buy the bits to make my 2nd one, so I'll do a parts list when I do that
PostPosted: Wed Jan 14, 2009 8:15 am
There's gotta be someone on here that has access to 'mass produce' PCB's???
Users browsing this forum: No registered users and 268 guests
