It is currently Sun Jun 22, 2025 1:47 pm
Post new topic Reply to topic  [ 353 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 24  Next
PostPosted: Tue Jan 06, 2009 1:37 pm
I totally agree. What's $150 in the long run? I'm getting towards the end of my project (but will it ever end?) and it looks like I might be able to finish the car for around 10 grand so $150 truly is almost nothing.
I would prefer the car to be simple and straight forward but of course, if the Rover tank won't cut it I will upgrade. I'll be running the engine with stock power for a while so that's not a huge amount of grunt and I'll probably need to upgrade later. I wonder if the Rover pump can be swapped to a larger capacity one? Maybe something like an MGF or similiar might fit?
PostPosted: Tue Jan 06, 2009 2:30 pm
There are many small submersible pumps that would fit inside the tank, both aftermarket and used. Stock WRX pumps can be picked up for $20 to $50, but you would need to make a way to secure it (when fitting an aftermarket pump to an Sti it's usually just cable tied to the existing bracket).
Internal pumps are neat & quiet, but VL Commode pumps are cheap and easy to fit - already sold my one though.
PostPosted: Tue Jan 06, 2009 7:54 pm
Yep definently going another pump,I want to make sure i have plenty
of fuel supply and as JC said a surge tank. the motor will be basically
stock but better to have good fuel supply at all times rather than
a bit of starvation
cheers Hallsey
PostPosted: Sat Jan 10, 2009 7:51 pm
Test fitted the sports pack arches on the dunger shell today. I have'nt
got the rear spacer drums on so the rear wheels are in a bit
Cheers Hallsey
PostPosted: Sat Jan 10, 2009 8:12 pm
Looking good there Hallsey, wont be long now Ol' Son!!
PostPosted: Sat Jan 10, 2009 8:19 pm
Not enough hours in the day Tricky , mind you not enough folding stuff
in my wallet either. I'm eagerly waiting an El gato update by the way :D
Cheers Hallsey
PostPosted: Sun Jan 11, 2009 12:57 pm
Looking good Hallsey,
I love those arches. Shame I can't get them to fit my car...
Madmorrie
PostPosted: Sun Jan 11, 2009 2:39 pm
Thanks MM i reckon they look pretty good, hows the morrie going?
Have you had frank back for a second look yet?
cheers Hallsey
PostPosted: Sun Jan 11, 2009 8:55 pm
Cheers Hallsey
Soon my pet, soon!!!!
PostPosted: Mon Jan 12, 2009 8:47 am
Hallsey
The morrie is making incremental progress. Trying to sort out everything in the engine bay then I'll pull the frame for final bracing and welding. Then I'll get Frank back...
Madmorrie
PostPosted: Fri Apr 10, 2009 5:15 pm
Time for a bit of an update, progress has been slow but steady, I got my
power booster and air box sorted so here's a few pics
Air box is from a fiestiva
I cut out the old radiator area for the air box, its a fairly good fit, I'll tidy
this up when i put it in the good shell
Put a nutsert in the frame for a stabilizing bracket
Then made a little rubber mounted bracket
Fitted up its nice and solid
The cars away getting the radiator made , hope to get it back tomorrow
cheers Hallsey
PostPosted: Fri Apr 10, 2009 5:20 pm
That's a very neat way to fit your airbox, well done.
Dicko
PostPosted: Fri Apr 10, 2009 5:46 pm
Thanks Dicko,gotta make do when there's not much room
cheers Hallsey
PostPosted: Fri Apr 10, 2009 7:38 pm
That works Hallsey, well done Ol' Sock!
PostPosted: Fri Apr 10, 2009 10:13 pm
nice work with the air box mate looks like in belongs there. keep up the good work.
Cheers Dan
