It is currently Tue Jul 29, 2025 3:48 pm
PostPosted: Fri Jan 16, 2009 2:06 pm
hi there
I have a 97 Rover Mini which has "peppertree" (or something like that) wheels on it.
We have to use a little plastic lock nut cap remover to take the wheels off and ours just broke!
Does anyone know where to get one from please?
thanks
Deb
PostPosted: Fri Jan 16, 2009 2:51 pm
"pepperpot"... cos it looks like a pepper shaker, doesn't look like a pepper tree :D
you could try various spanners and things - I got my dad's locknuts off his superlites by putting an open ended spanner at right angles to the nut and twisting it with a screwdriver...
or a centre punch, but then you'll need new nuts, but they're not much good without the locknut key
PostPosted: Fri Jan 16, 2009 3:43 pm
If the car is drivable I'd go down to the local wheel shops and ask if they have either:
a. anything that fits you could buy, or
b. anything that fits so you can remove the nuts and buy a new set of locknuts later.
Failing that, I've used a cheap socket and hammer with success a few times.
:D
PostPosted: Fri Jan 16, 2009 4:04 pm
My new van came with those famous words " the socket for the lock nuts is in one of those boxes I think" must of been the other box :lol: 2 came off with a socket and hammer and the other 2 removed with an air chisel, 4 new nuts and all is good
PostPosted: Fri Jan 16, 2009 9:39 pm
:D
I was the perfect example of this :lol:
I had Lock Nuts on the Alfa 75 and lost the Key for the lock Nuts :roll:
I hammered a socket onto each and removed them :wink:
Mind you be carefull....if you have to change a tyre due to a flat and you still have this problem....your in the Poo :roll:
Find a Key or atleast get them off
PostPosted: Fri Jan 16, 2009 9:42 pm
i ended up using a center punch and just tapped the holes around.
Users browsing this forum: No registered users and 126 guests
