It is currently Sat Jul 19, 2025 2:35 pm
PostPosted: Fri Jan 16, 2009 7:35 am
hey there im a new mini owner bought mine couple of days ago its got the 998 motor and its been overheating. I put in a new thermostat and flushed the radiator no change. there are no leaks I can see either. would someone be able to tell me how to check the water pump and what else it could be.
The car also misses and has a few dead spots when I got it 3 days ago it drove fine but was just overheating. I put in a new distributor cap and spark plugs still same thing will this car need tunning but it was fine 2 days ago.
what should I check for these dead spots and miss firing.
any help will be appreciated thanks guys.
PostPosted: Fri Jan 16, 2009 7:46 am
High heel ninja
Check your timing.
Doogie
PostPosted: Fri Jan 16, 2009 7:54 am
As doogie said, check your timing. It will cause it to miss and overheat.
RYan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Fri Jan 16, 2009 8:26 am
also your points are correctly adjusted to the right thou
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Fri Jan 16, 2009 8:42 am
can anyone tell me how to adjust the timing im a newbie to this.
and do you mean adjust the carbie or the timing under the rocket cover
and what should be the correct distance
thanks guys
PostPosted: Fri Jan 16, 2009 8:57 am
where abouts are you located?
you'd be best off taking it to a mechanic I believe..
or at least buy/download a haynes mini manual which will step you through the basics..
tim
PostPosted: Fri Jan 16, 2009 9:01 am
High heel ninja
Micky, if your new to minis it might pay to get someone who knows what there doing to give it a once over, check the timing, tappets, set the points etc etc.
I'd recommend Greig @ Mini Classic @ Ermington 98747211
or
Tony @ Minispares @ Padstow 97743366
It won't cost you a lot of money for a tune up.
Doogie
PostPosted: Fri Jan 16, 2009 10:51 am
definitely take it to a mini expert to get everything set up properly, then if you want to play, you have a good starting point to work from - any changes you do right now will be just stabs in the dark
fill in your location, and we'll be able to recommend where to take it
PostPosted: Fri Jan 16, 2009 9:51 pm
someone can come over and give you a run down on a few things :wink:
Put a BBQ and a case of beer or two and you'll have a Great Day
PostPosted: Sat Jan 17, 2009 8:18 pm
im located in baulkham hills.
PostPosted: Sun Jan 18, 2009 3:22 pm
damn too for away for me for free beer
www.minisprintgt.com
