It is currently Sat Jul 19, 2025 10:57 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jan 18, 2009 4:08 pm
so a type 1 tandem master cylinder doesnt push twice the amount of fluid as a single?
i figured from no travel to halfway is equal to the full travel of a single master cylinder
and the other half travel would just create greater pressure
or should i rig up 2 master cylinders like the kad brake set you can buy
for the effect i want?
1969 Blue Mini K, 1330cc, Weber 45, polished aluminum roll cage, Race seats, 4 point harness, full rewire incorporating 8 fuses, 6 relays and new headlights :) just needs tyres front shocks and a windscreen til re-register
PostPosted: Sun Jan 18, 2009 4:32 pm
No No No No No No...
It does not push twice as much fluid. It pushes the same amout of fluid out of two holes. One hole for the front brakes and the other hole for the rear brakes.
It is only there in case something fails you still end up with half your brakes working.
Please learn how things work before ****ing with them. You are going to hurt somebody.
PostPosted: Sun Jan 18, 2009 4:52 pm
thanks i wasnt sure how they worked so i hoped someone here knew how they worked
thank for your help morris 1100
