It is currently Fri Jul 18, 2025 10:22 pm
 Post subject: Clubman Door Mirrors
PostPosted: Sun Jan 18, 2009 8:45 pm
Hello,
the Clubman mirrors are quite shaky, but I can't seem to see how to tighten them up.
I was inside the door trim securing a loose door lock and tried to "feel" up inside the door to see how the mirrors are attached, but came up short - I couldn't figure it at all.
To me it seems there is a secure base plate with the mirrors somehow attached... but I have no idea and it bugs me.
Anyone able to set me straight - or point me in direction of new/better mirrors :D
thanks
Graham
PostPosted: Sun Jan 18, 2009 8:49 pm
Take a look at the back of the spring loaded arm where it meets the body. If you look carefully you will find a screw facing forwards. Loosten this screw and the body will come off the mount.
Then tighten up the mount and re-fit the body.
Hang on I will take a photo...
PostPosted: Sun Jan 18, 2009 9:06 pm
Here is the screw....
This is what the mount looks like...
Here is a screwdriver on the screw...
 Post subject: mirrors - fixed
PostPosted: Sun Jan 18, 2009 9:15 pm
Hi
Thanks - I went and checked
A bit tricky to find "exactly" the right screwdriver, but with that done it was exactly as described and as easy as.
Two snug mirrors now :D :D
Graham
PostPosted: Sun Jan 18, 2009 9:16 pm
The trick it that the arms have to be on the right angle to allow the screwdriver in.
I am glad it worked. The really are great mirrors and they look right.
PostPosted: Sun Jan 18, 2009 9:25 pm
Milatsmadmini
if you get bored of them ill have it :lol:
