It is currently Sat Jul 05, 2025 5:12 am
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Feb 15, 2005 10:19 pm
Looks like i started a good topic...
Yet again! :lol:
Its what we're all about tho... learning new stuff. :wink:
PostPosted: Wed Feb 16, 2005 12:44 am
willy, get your head work sorted out.
Enlarge the inlets, deshroud the valves, maybe even go for unleaded conversion.... make the air flow better, its the best power gain.
Buy a spare head (I've got a spare 12g202 here :wink: ) and give it to Steve's dad.
PostPosted: Wed Feb 16, 2005 7:28 am
Kev, not too many people know about those alternative, closer ratios from the 3 synchro's. The original gearbox out of my Black Mk 1 S has those ratio's, same ratio's as SC gears, very nice gear set on the road, especially coupled with 3.7 diff ratio. Do you which gears were actually different? I've never checked it and it's still all together. Steve
PostPosted: Wed Feb 16, 2005 6:29 pm
Not sure Steve, here's the guf on CR helical from Vizard's HTMYM.. p136
1st 2.568
2nd 1.780
3rd 1.242
4th 1:1
1st motion had 23T, 2nd gear 29T, 3rd gear 25T
Laygear (cluster) had 24,21,17,13.
Sounds like 1st gear outer ring and its hub was stock 3 synchro, as per the SC box.
HTH,
:wink:
PostPosted: Wed Feb 16, 2005 6:34 pm
Head work yeah.
Whats a good head to start with?
Say what now with giving a head to reg? Is that for HIM to work on it, coz ive seen him a couple of times perched there with the die grinder.
Do all heads fit on 1098 blocks? Scuse my noobness.
What does a head cost, and what will the work done TO it cost?
Thanks Nath.
PostPosted: Wed Feb 16, 2005 9:03 pm
Thanks Kev, that will help, just need to find the corresponding numbers for stock box and S ratios. Steve
PostPosted: Wed Feb 16, 2005 9:13 pm
12G295 is THE best small bore head stock...rare as hell and expensive if you find one...~$600ish
Any of your other options are going to take a long time to port to make even close to the 295..
You probably have a 202 head on now..i'd say stick with that and work it so that it's comparable to a 295..
You could go a 12G940 (off a 1275) and pocket the block as well..
PostPosted: Wed Feb 16, 2005 10:06 pm
Here ya go...
Stock Mini 3 synchro:
1st 3.627
2nd 2.172
3rd 1.412
Cooper & S, 3 synchro:
1st 3.2
2nd 1.916
3rd 1.357
4 synchro standard
1st 3.52
2nd 2.22
3rd 1.43
Mk2 S
1st 3.3
2nd 2.07
3rd 1.35
Of course, all have 1:1 4th gear..
:wink:
PostPosted: Thu Feb 17, 2005 1:31 am
So doc, can these ratios be mixed and matched..... say you want the first ratio from 1 box, second from another box, etc etc??
willy.... ive got a spare 12g202 head sitting here..... its yours for 20 bucks. I WAS only going to use it for my own attempt at porting and polishing.... :lol:
Yeah, Reg does some P & P in the cave...... not sure if its actually his "job" though. Steve will tell ya a price. My quoted prices are a little different to yours :wink:
Not all heads will bolt straight onto different blocks. You have an 1100, your head will be a 12G202. Different heads might not fit without modifications. As Mini Mad said, the block might need pocketing. This requires a full strip down of the motor so that 2 steps (pockets) can be milled out of each cylinder bore. This is to stop the valves from hitting the block and smashing to pieces.
Its cheaper for you to modify a 202 :wink:
PostPosted: Thu Feb 17, 2005 5:51 am
No you can't- it's not a Hewland or Holinger etc racecar box where you can slide different gears in.
Ratios are fixed for each set, as Mini cluster gears are all one piece- each set uses a different cluster.. and the 2nd & 3rd gears on mainshaft are matched to the cluster.
:wink:
PostPosted: Fri Feb 18, 2005 1:39 am
well, there goes THAT idea....... :roll:
PostPosted: Wed May 18, 2005 11:07 pm
Okkher so.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&category=32072&item=4547217728
There you have a SC/CR gear set 4 syncro.
A tad under 1300 dollars.
Worth it?
Do they scrub out quickly?
For at the moment they would be wank value - one can only love the sound of a SC gearbox 8)
Are these gears very loud? I've seen a few rexxies with SC gearboxes and theyre pretty loud! Would these be as loud?
Later on, i'll be acquiring a 1275 that i'll slowly modify to be a nicely stinking hot road donk.
Can i simply swap these SC gears over into the 1275 gearbox once i've (the machinists) finished working the titties of it?
PostPosted: Thu May 19, 2005 8:03 pm
big willy wrote:
Okkher so.
Cheaper to bring a set in from UK as Ozmotorsport did..
Worth it? Depends.. for track yes, for road it's debatable. You would probably want a shorter diff ratio, as 1st gear is a lot taller.
Won't last as long as helicals, in a road car.
Yes they are a bit louder, but if you REALLY want loud buy some straight cut drop gears.. :lol:
Depends which 1275 box you have and which SCCR gearset this is. There are different sets for A+ and pre-A+ boxes.
 Post subject: .
PostPosted: Thu May 19, 2005 8:28 pm
willy, you're a tool. ther is simply no sch need for a SC ger set on the street. Too much noise, too bloody expensive, and... wait... You've only got an 1100. *Yawn* No 1300, no haed-work, no huge cam. You're better off spendin your cash on a 1275, some decent head work (i spent $1000 alone on the head) and a nice cam. Still no need for the straight cuts.
Or just learn to drive it as it is...
 Post subject: Re: .
PostPosted: Thu May 19, 2005 8:34 pm
Stuwey_LS wrote:
Blah blah blah, crap crap crap, .... no haed-work...
Err... who told u that?
And dont u read things properly?
I wrote previously: " Later on, i'll be acquiring a 1275 that i'll slowly modify to be a nicely stinking hot road donk.
Can i simply swap these SC gears over into the 1275 gearbox once i've (the machinists) finished working the titties of it? "
:roll:
Internet n00b. :roll:
