It is currently Fri Jul 18, 2025 10:08 am
 Post subject: hand brake
PostPosted: Thu Jan 22, 2009 1:30 pm
g'day all my car is nearly complete and i am looking forward to registering it. the only thing is i have a problem i have bled and bled and bled my brakes so there is no air in them and also have adjusted my wheels several times but still do not have much pedal. my hand brake is also basically adjusted all the way and it doesnt hold my car and when driving doesnt lock up my wheels when handbrake is reefed on. does this mean worn brake pads? because the pads to me look ok but i am no mechanic how much meat on the pads is plent and how much is not enough time to replace?... thanks a lot fellas
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Thu Jan 22, 2009 2:05 pm
Don't forget the brake drums. Will give same symptoms as worn shoes.
PostPosted: Thu Jan 22, 2009 2:34 pm
High heel ninja
Your cables are probaly stretched,, new ones are cheap, $20 each from memory.
But the tight ass way to do it s to tie a knot in the cable, undo it from the handbrake, pull the cable out thru the floor, tie a knot & reverse removal procedure.
Doogie
PostPosted: Thu Jan 22, 2009 3:35 pm
nice...... but what about my brakes they dont lock up when brakes slammed on? i have tried different drums incase they are worn but still same problem. how do you tell if your pads are worn?
1970 mini k
1975 leyland
PostPosted: Thu Jan 22, 2009 3:38 pm
ginger ninja
ginger ninja
Have you take them off and had a look? (might be a blonde question but i thought i'd ask :?)
sports850 wrote:
PostPosted: Thu Jan 22, 2009 4:01 pm
High heel ninja
Are the brake shoes in the right way?
Doogie
PostPosted: Thu Jan 22, 2009 4:05 pm
Do the wheel cylinders actually work? Could the pistons be stuck in the bores?
PostPosted: Thu Jan 22, 2009 4:37 pm
Tomboss Breweros
Your brake shoes are worn out when you run out of adjustment.
The best way to adjust the handbrake is to loosen the cables, re adjust the rear drums then readjust the cables.
Still, with reasonable adjustment and bleeding your brakes should stop reasonably hard.
NOTE - if you try to stop from 130 in a hurry, it wont happen with drums. :(
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Jan 22, 2009 5:44 pm
tried tying the cable in a knot but still not locking up back wheels.......and also still have adjustment in the wheels/pads i pull the hand brake up as hard as i can but can still move it when pushed although it is hard.
1970 mini k
1975 leyland
PostPosted: Thu Jan 22, 2009 6:30 pm
Tying a knot in a handbrake cable is a defect.
PostPosted: Thu Jan 22, 2009 6:39 pm
so it would fail blue slip when taken in?
1970 mini k
1975 leyland
PostPosted: Thu Jan 22, 2009 6:44 pm
how many mm do you need on each pad before you say buy a new set?
1970 mini k
1975 leyland
PostPosted: Thu Jan 22, 2009 8:33 pm
Have you had the master cylinders replaced? Could be you have the clutch master cylinder on the brake side? Just a thought
Dave K.
PostPosted: Thu Jan 22, 2009 8:45 pm
If the hand brake quadrants are in back to front the handle will be hard but the brakes will not be fully on.
You need a knowledgeable person to look at the hardware - lots of guesses otherwise.
Cheers, Ian
PostPosted: Thu Jan 22, 2009 9:28 pm
if the master cylinder is indeed a clutch not a brake is it possible that this could be the problem? is there any difference between the clutch and brake cylinders? because i had one and not knowing weather it is a brake or clutch put it on?????? would this cause me not to have pedal or very little pedal and be able to push it to the floor?????
1970 mini k
1975 leyland
Users browsing this forum: Bing [Bot] and 90 guests
