Well now I have a plan , I tried the heat shields on with the carb and the throttle arm on the carb on the right in the photo hits the shield with it in it's normal position ,
So I flipped the right hand side of the shield over (experimental mode) and it all fits nicely , the shield itself is about 1/2" too wide too and touches the THIRD SPRING point on the shaft joining these carbs (this shaft will go on mine) but it all theoretically gives enough points to mount the 3 springs without any drama's .
Now to get some steel and make up something similar (not going to modify this one , might need it one day) with an extra leg out the right hand side to fit the spring on the right hand carb .
Extra question though , how useful are the heat shields , should I make the plate with them on or just cut them to fit the carb flanges ? I'll make it in a similar 3 piece design but not sure whether to make the carb pieces wide enough to work as heat shields as well or not ???
