It is currently Fri Jul 18, 2025 5:44 pm
 Post subject: Photo request
PostPosted: Mon Jan 26, 2009 4:28 pm
Hello peoples!
Just wondering if anybody out there is able to provide me a photo (or better yet the actual thing!) of a clubman door lock barrel?
I could also use measurements and if possible, I'd like to know what the door looks like on the inside to hold it in. Is it just a shaped hole or is something welded inside?
Thanks.
:D
 Post subject: Re: Photo request
PostPosted: Mon Jan 26, 2009 4:42 pm
Harley wrote:
Hello peoples!
Thanks.
:D
The hole is round but with two flattened sides - imagine a round chocolate cream cake (3 layers) and cut two pieces off each side shaped like the harbour bridge, whats left is what the hole looks like.
There is nothing special about the door, the lock is held by a spring with two ears that clamp it to the panel
Daniel
PostPosted: Mon Jan 26, 2009 9:23 pm
Nice photo Doz, but didn't he want the actual lock barrel? :oops:
PostPosted: Mon Jan 26, 2009 9:38 pm
Yes - but I don't have one. But he also wanted to know what the inside of the door looks like - it's the same as the outside hence my photo of the door I chucked out on the tip run.
Daniel
PostPosted: Mon Jan 26, 2009 9:41 pm
got ya covered, just gimme a few minutes :D
78 Leyland Mini - Prince
PostPosted: Mon Jan 26, 2009 10:38 pm
ok here we go... originally i had reservations about posting pictures of my door lock, but then i remembered there are only three or four different keys anyway :P. anyway, have some pics.
this notch at the back goes around about a quarter of the way. 2mm wide
the tabs are 1mm apart
diameter where taper starts: 7mm
diameter where taper stops (eg, that hole...): 5mm
total length: 31mm
width of chrome cap (bottom) 3mm
(top) 2mm
with of that second lip that goes around the bottom: 2mm
here's what it looks like with its key in
and from the bottom
PostPosted: Mon Jan 26, 2009 10:39 pm
ok so it took nearly an hour. shutup :P
PostPosted: Tue Jan 27, 2009 7:35 am
Dylan you are a legend in your own undies! :D
That helps immensely! Thanks a lot!
PostPosted: Tue Jan 27, 2009 8:55 am
So that would be rarely a legend?
PostPosted: Tue Jan 27, 2009 9:36 am
There are actually about 40 different keys
My dad has the genuine key-board
PostPosted: Tue Jan 27, 2009 2:54 pm
i don't own 40 pairs of undies, what are you talking about???
PostPosted: Tue Jan 27, 2009 3:21 pm
Might help a bit...
http://www.minisport.com.au/prod681.htm
