sounds like you're getting it under control - with regular maintenance, a mini's cooling system is well up to the job
74snail wrote:
Now having the hot exhaust gases coming out there seems to have had quite an effect on the car in hot weather
a leaky exhaust also causes turbulence in the exhaust, basically making a blockage in it, the engine can't push the exhaust out so it retains more heat in the motor, and it robs power, meaning the engine has to work harder to make the same power (to travel at speed)
did I tell you that I won a
trophy?
