It is currently Mon Jul 21, 2025 10:00 pm
PostPosted: Thu Jan 29, 2009 10:22 pm
Drove over a large hole in the Moke,which resulted in the LHR radius arm shaft(pin) breaking.This is the 13inch wheel type,ie bearings on the shaft.
I put my "butchers apron" on and removed the nut off the shaft,thinking that I could punch the shaft thru the other side,but it won't move?
Do I have to punch it thru from the inside,or doesn't it matter....and just keep using a bit more force?
Thanks.
PostPosted: Thu Jan 29, 2009 10:29 pm
It`s most probably siezed in the arm,,, take the outer bracket bolts out , one bolt is in where that blue thing is & another under the arm,,, & 2 more under the bracket & take the whole arm & bracket off the car, obviously you`ll need to undo the brake hose & handbrake cable etc to achieve complete removal of the arm from the car.
once it`s out you can sort it from there
i have 2nd hand arms if you need them
PostPosted: Thu Jan 29, 2009 10:32 pm
Tomboss Breweros
If its anything like a normal mini (i've never had a moke) you will need to undo the nut on the inner end of the shaft, remove the bracket that mounts the outer end then you should have some luck for removal.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Jan 29, 2009 10:55 pm
The inner nut and a section of the shaft is where it snapped,I removed that with a pair of plies-and was hoping that I could then punch the broken section out and replace it without removing the complete unit?....Is the shaft on a Mini,which runs on bushes,the same as the Moke with the bearings?
 Post subject: jay
PostPosted: Thu Jan 29, 2009 11:30 pm
na you cannont punch the shaft out with the arm still in place it has to come off to get the broken shaft out im afraid... it will be good for it anyway you can inspect the needle bearings and give them a bit of grease while you are at it..
if you remove that arm bracket (4 bolts) on the outside of the car and the one nut from the inside of the sunframe that holds the shaft in, you can remove the complete trailing arm, but best to disconect the handbrake and brake line and inspect it on the bench, cause i have seen thoese needle bearing cases crack and bearings go everwhere, wont do your new shaft anygood..
Is the shaft on a Mini,which runs on bushes,the same as the Moke with the bearings? YES.
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Fri Jan 30, 2009 6:34 am
It is the same shaft as a Mini but has a needle bearing at BOTH ends. Great idea, as long as it gets greased, yours looks like it had a holiday from that chore.. :lol:
PostPosted: Fri Jan 30, 2009 8:23 am
It is the same shaft as a Mini but has a needle bearing at BOTH ends. Great idea, as long as it gets greased, yours looks like it had a holiday from that chore.. :lol:[/quote]
Thanks Kev-Yes well spotted,I'm not sure whats been neglected more lately......The Moke or the wife :wink:
PostPosted: Fri Jan 30, 2009 8:30 am
Wives cause a lot more trouble than a broken suspension if neglected.
PostPosted: Fri Jan 30, 2009 9:04 am
but both respond well to occasional lubrication
PostPosted: Fri Jan 30, 2009 10:17 am
:? So what are you saying BIAM.....they also like a new shaft when the old one is worn out :?: :lol: :lol: :P
PostPosted: Fri Jan 30, 2009 4:04 pm
And with the roller bearings we can avoid the task of reaming :roll:
PostPosted: Fri Jan 30, 2009 8:34 pm
Should I use "high melting grease" as a lubricant?
PostPosted: Fri Jan 30, 2009 8:54 pm
Don't start Them :roll:
You have to undo the nut on the other end of the shaft to take the Arm Out
Moooooo What time is it
You have no choice but to fix it properley :twisted:
PostPosted: Fri Jan 30, 2009 8:59 pm
Gaf ROTFLMAO ^^^^
You're a funny Bvgga! :P :lol: :lol: :lol:
Graham
Sir Alec! we are not worthy!
Users browsing this forum: watsupskip and 106 guests
