It is currently Sat Jul 26, 2025 10:17 pm
PostPosted: Wed Jan 28, 2009 9:44 pm
Can someone confirm when the plastic master cylinders were introduced on the Mk2.
What should be on YG2S4 1381, engine 9FXEY54278?
I belive it should have the Mk1 style booster, but not sure of which cyliders.
I suspect Plastic clutch, but not sure of the brake.
What brand plastic cylinders? Lockhead or PBR?
PostPosted: Wed Jan 28, 2009 10:35 pm
This space for rent
I don't know about the Mk2 S, but FWIW my 6/70 K (same vintage) has the large circular plastic-reservoir Lockheed master cylinders on both brake and clutch.
PostPosted: Sat Jan 31, 2009 8:32 am
Guys,
Does anyone have the body numbers from which the plastic master cylinders were fitted to the Cooper S???
PostPosted: Sat Jan 31, 2009 4:23 pm
The Forkmeister
Mate, PM John Smidt or give him a call (o246481233), he'll set you straight with your master cylinders.
Cheers Gerg
May the fork be with you.
PostPosted: Sat Jan 31, 2009 6:45 pm
My 4/70 had two plastic types, my 6/69 has two tin types...
PostPosted: Sun Feb 01, 2009 10:11 am
The Mini King
This May start a debate,
However, over the years as some people would be aware, I have bought a lot of damaged and straight Cooper S Cars, And I remember some very early Mk2 Cooper S with Two tin tanks, Then the Plastic tank Master Cylinder was used for the clutch only, later on the Mk2 was fitted with two plastic tank Master cylinders, To the best of my memory the first Plastic tank master cylinders had BAI cast into the body of the master cylinder, I have misplaced some of my records so at this stage I cannot give acurate introduction dates of the various master cylinders, I will however keep looking for My records and advise these dates if I find them
PostPosted: Sun Feb 01, 2009 3:16 pm
BAI was the parent company of AP, Borg & Beck and Lockheed.
Could the timing of the introduction of the plastic tanks be related to an ADR? (hang on, that can't be right because Holdens still had solid tanks in the late 70s) :?
PostPosted: Sun Feb 01, 2009 3:29 pm
Online
Nope, the 78 Clubbies with the tandem MC had a tin tank clutch MC. The plastic one didn't fit... no room left. :lol:
PostPosted: Sun Feb 01, 2009 3:30 pm
I was thinking more about brakes. :lol:
PostPosted: Sun Feb 01, 2009 3:32 pm
Online
OK back onto plastic crappy brake cylinders then.. :lol:
When did the Lockheed plastic cap cylinders give way to PBR (same type) or were these just aftermarket MCs?
Users browsing this forum: drmini in aust and 88 guests
