It is currently Wed Aug 06, 2025 1:16 am
 Post subject: HELP
PostPosted: Sun Feb 01, 2009 8:12 pm
Thread dig,, I need help!!
How do I remove the flywheel, i know with the flywheel puller, but the 3 bolts that are needed to fit into the puller, anyone know what size i need??
Thanks!
You can't drive your shares on the weekend...
PostPosted: Sun Feb 01, 2009 8:29 pm
The 3 bolts are 3/8" UNF on all non-Verto (ie Rover) flywheels. You want Grade 8 bolts.
You also want a thick pad in the middle of the crank for the centre bolt to bear on. I use a short 5/8" bolt with the threads turned off it. But some people use the flywheel bolt screwed almost in, , after removing the keyplate.
<edit> for those wondering, the Verto flywheels use M10x1.5 bolts.
PostPosted: Mon Feb 02, 2009 8:41 am
So just double checking, for mine, (a mini k, so not a rover)
I will need M10 X 1.5 ...
PostPosted: Mon Feb 02, 2009 8:43 am
No no, 3/8 UNF.
Doc meant "non-verto" as a clutch type which is found on Rover cars. SO as you have a Morris, you will need 3/8 UNF.
PostPosted: Mon Feb 02, 2009 9:43 am
Mick wrote:
No no, 3/8 UNF.
All Oz made cars are non-Verto, I should have been clearer. :wink:
PostPosted: Mon Feb 02, 2009 4:19 pm
O.K. Thanks guys!
:wink:
PostPosted: Mon Feb 02, 2009 8:17 pm
Does anyone know if these 3/8 bolts exist anywhere on the car?
I have found one, dunno what from tho?? And i need 2 more.
I bought some, but they arnt long enough! :oops:
PostPosted: Mon Feb 02, 2009 8:32 pm
Go buy some decent 3/8 UNF bolts about 4" long. You want Grade 8.
Reason-
If they strip under the heavy load here, you are in trouble.
PostPosted: Mon Feb 02, 2009 8:38 pm
Doh... meant to have it in to the mechanics tomorrow for the rebuild. oh well.
Users browsing this forum: Bing [Bot] and 94 guests
