It is currently Sat Aug 02, 2025 6:01 pm
PostPosted: Sun Feb 01, 2009 10:51 pm
i have drilled the top part of the crash pad in.
now where do i fit the dash. do i need to dill more holes.
i have all the brackets the 3 metal long brackets
seems like it just clips in & tighten the butterfly bolts up.
i'm a bit confused with the bottom crash pad.
is that just glued in?
how does it all sit..?
PostPosted: Sun Feb 01, 2009 10:55 pm
Die Die Die!!
top crash pad is screwed in,
bottom crash pad is spray adhesived on.. then you have a metal lip on the inside.. like a chrome strip that goes over..
as for the dash there are 2 types can you get a pic of it ?
PostPosted: Sun Feb 01, 2009 10:59 pm
i have this dash..
& it is going into a 1964 van
http://www.ausmini.com/forums/viewtopic.php?t=49713
PostPosted: Sun Feb 01, 2009 11:00 pm
Die Die Die!!
i should have been more specific, do you have any pics of the dash mounts.. as their are 2 types of mounts...
PostPosted: Sun Feb 01, 2009 11:01 pm
i also have the rover light switches to go with it.
PostPosted: Sun Feb 01, 2009 11:06 pm
um.. no.
what are they.?
looks like that???
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0316419682
PostPosted: Sun Feb 01, 2009 11:08 pm
i bought the dash out of an rover so the kit is all done.
but it looks alot like that.
99% sure that's what it is.
Die Die Die!!
oh well thats quite easy then, no drilling required from memory, just just your hand in under neath the dash on the drivers side and through the glovebox or airvent on the passenger side from memory
PostPosted: Sun Feb 01, 2009 11:10 pm
ok cool..
what did you put behind the dash.
to enclose it from the engine bay?
if i put something in the dash it would slide up to the drivers side.
any idea what i should put behind to sound proof it?
dynamat? some one reckons it smells when hot?
or what do the rovers have behind there?
PostPosted: Sun Feb 01, 2009 11:12 pm
Die Die Die!!
i dont beleive they have anything behind them...its full of wiring ect, but if need be you could always put dynamat or that hessian engine firewall stuff in there the sky is the limit :)
PostPosted: Sun Feb 01, 2009 11:14 pm
wicked..
you are a great help mate..
woot i cant wait to get this thing on the road.
so close.
i just ordered a center dash as well. so it's going to be pimping/cramped lol
:D
PostPosted: Mon Feb 02, 2009 7:31 am
The rover sound deadening is a 1 inch thick layer or dense sponge with a 3mm layer of hard rubber glued onto it.
