Actually I have further advice, if the wheel nut is hard to budge (chances are it will be) get a mate to stand on the brake pedal inside the car while you undo the nut. Try using a long pipe as an extension. I have found that even this sometimes is not enough to pop the nut. Nut size will depend on if you have disks or drums.
Don't forget to remove the split pin before trying to undo the nut!
You'll also need a ball joint splitter... Fun task on 20+ year old joints... just be brutal but gentle if that makes sense. If I were you I'd redo all the ball joints again while I have it out.
Also if you have discs, when re-assembling make sure the drive flanges sit flush and true on the rotor. I had this problem and the wheel nut came loose once it settled in after a few drives
