I use KMX.
I used to run HPR30 im my Morris for about 8 years. It always slightly leaked oil from the crank seal and the driveshaft seals. It also had mayo in the rocker cover for most of winter.
When I switched to KMX the car suddenly stopped leaking oil past the seals. The mayo in the rocker cover has reduced.
It is cheap oil, it is good oil and you are not paying through the nose for an advertising campaign.
Why would you run anything else?
I got 2 more 6L cans of KMX today, $18 or so each. KMart had Castrol Edge Sport 25W/50 on runout special, $35 for 5L.
That's why I use KMX... it does the same job at way less than 1/2 the price.
I can afford to change it every 1500 miles...
<edit> I said earlier that KMX is an SF- I was wrong, it's SG.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
