It is currently Mon Jul 21, 2025 4:01 pm
PostPosted: Thu Jan 29, 2009 10:53 am
Hi All,
I was wondering if anyone has any tricks for removing the glue and hair that's used to attach the interior trim in the car.
I dont want to use paint stripper as it will just create more work.
Dave
PostPosted: Thu Jan 29, 2009 10:55 am
ginger ninja
ginger ninja
metho maybe? Are you talking about the glue that holds the carpet etc?
sports850 wrote:
PostPosted: Thu Jan 29, 2009 11:14 am
Hi,
Yep, it's the glue that holds the trim on the dash board and around the wheel arches.
Thanks
Dave
PostPosted: Thu Jan 29, 2009 11:21 am
I've recently removed insulation from under a bonnet on a non-mini.
Believe it or not, a stainless steel painters scraper is the best tool. I didn't like the idea when I was told it, but it did a great job.
PostPosted: Thu Jan 29, 2009 11:43 am
might sound weird, but eucalyptus oil is the best thing to get rid of glue. End up smelling like a koala tho.
PostPosted: Thu Jan 29, 2009 12:20 pm
I use Shell Toluol/toluene and that takes off the softer stuff. Where it has gone rock-hard, I use a 2" Scotchbrite pad on my small air die grinder. Done gentley, it does no harm to the paint.
Regards
Al
PostPosted: Thu Jan 29, 2009 12:26 pm
Turps will dissolve it, not as fast as koala farts(eucalyptus oil) however.
PostPosted: Thu Jan 29, 2009 12:43 pm
Ive used 3M Contact Adhesive Remover in an aerosol can. Not sure how it would go on old glue, but when I was doing my interior with fresh contact adhesive it came in very handy.
PostPosted: Thu Jan 29, 2009 12:45 pm
The solvents will get through it, have to keep it wet with the stuff while it works. I removed some after 8 years around my rear window.
PostPosted: Thu Feb 05, 2009 7:15 pm
Thanks for all the suggestions.
I'll let you know which one works
Dave
Users browsing this forum: Gambo and 76 guests
