It is currently Tue Jul 15, 2025 4:25 pm
PostPosted: Sat Feb 07, 2009 9:50 am
Hello, im reasonably new to minis
I've got one of matt's bmw conversion which i was going to put onto my mk2 cooper s engine, but have since decided to leave this engine as is and build a reliable purpose built engine.
i was thinking a fast road engine along the lines of reconed 1275 rebored to 1293cc with gearbox and 4 pin diff, uprated flywheel, clutch, water/oil/fuel pumps, ecu.
My question is do u guys know if anyone in vic (preferably) who will sell or build an engine/gearbox combo and prepare it for the bmw conversion?
Im also open to any suggestions the car will be used fairly regularly so i would like it to be reliable and put out about 110hp
PostPosted: Sat Feb 07, 2009 11:02 am
Your best bet would probably be to send your stuff to Matt Read... as he has done all the machining before ... or speak to David Rosenthal who is here in Adelaide he might be able to help you with machining ...
Are you doing a 8 valve or 16 valve
Im in the early stages of doing a 8 valve onto a 1275A+ motor part of me still wants to make it 1380 but my sensible side says stay to 1275\1293..
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Sat Feb 07, 2009 11:23 am
Im doing an 8 valve also beanie
i've got to find a engine before i worry about machining
i spose i could get one from the wreckers (i haven't sourced this avenue yet)
PostPosted: Sat Feb 07, 2009 11:26 am
im also looking at getting one from the uk
they will do all the work for you ready for the conversion kit and head
but over 1000 pounds in shipping!!
PostPosted: Sat Feb 07, 2009 11:43 am
There's no point paying all that freight on machine work which is easily performed here. Not to mention the risk of customs asking for their share of the cost as well.
Your chances of finding a 1275 block in the wreckers is very slim, you would best be contacting some of the parts guys in the Mini business directory here: http://www.ausmini.com/forums/viewtopic.php?t=10543
Josh at Mini Imports brings in a lot of mini engines if you are after someone locally. Can also help with disc brakes etcetera as well to go with the conversion.
PostPosted: Sat Feb 07, 2009 11:49 am
thanks for the contacts mick, i'll do a ring around
PostPosted: Sat Feb 07, 2009 12:20 pm
There's a 1275 on ebay at the moment.
Steve
1964 998cc Cooper
1971 Mini K x 2
1972 Clubman GT
 Post subject: jay
PostPosted: Sat Feb 07, 2009 4:41 pm
Ive got a 1275 that i will part with, requires rebuild... PM me. located in edithvale
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Sat Feb 07, 2009 5:28 pm
PM sent clubmn
1971 mk2 police cooper s
1988 rover mayfair modified!!
