It is currently Sat Jul 19, 2025 12:45 pm
PostPosted: Fri Feb 18, 2005 8:36 pm
Yellow devil, before you fit your Brownriggs, get them HPC coated, $170 a few years ago not inc collector. Steve
PostPosted: Sat Feb 19, 2005 12:48 am
hey,
Im running Wildcat LCB extractors ATM,and im a pritty big fan of them,they are a very good flowing extractor that are cheap for there performance,iv also driven a cooper S with 3-1 perrys to the exhaust shop,then driven it home with its new Wildcats,and you can feel the :lol: factor,if intrested in the,,PM me or brickworx about getting a pair,i can grab some pic's of them if wanted,
the flow well enuff to let my car rev to 5500 RPM on a 1100 with 1 1/2 carbie
PostPosted: Sat Feb 19, 2005 6:04 am
I'm a big fan of LCBs- I've had Sonic, Perry, and Maniflow. Maniflow is much better made and they don't leak at the downpipes like the others, as they are joined underneath and actually have twin clamps...
But `Barney' has a Perry 3-1 (ex the 1098) and Lukey muffler on his 1293A+ now- we'll see how it goes with the twin HS4s... 8)
PostPosted: Sat Feb 19, 2005 10:39 am
from what iv been told, 3-1 extractors are for free flowing the gasses out of the head?and LCB use the exhaust pulse to draw the gasses out of the nexy cyl. and create a flow/suction?
If i had the money i would like to try a set of LINK extractors,they look honey as
PostPosted: Sat Feb 19, 2005 12:07 pm
I'm using a 3-1 only because the car already has it (nearly new system).
There is also a 3-1 Maniflow race manifold available, uses 3 LONG equal pipes. Supposed to be better than an LCB for racing. 8)
PostPosted: Sat Feb 19, 2005 6:32 pm
yep i think i no the ones you are talking about,they join up rite under the car,(like on the cover of vizards book)
my mate justin had some custom ones made up down at Exhaust Technoligy for his race car,they were not cheap but are DARN nice :wink:
PostPosted: Sat Feb 19, 2005 9:49 pm
Yep I already have that happening
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Sat Feb 19, 2005 9:52 pm
I have the 3 inot 1 on at the moment and I am not happy wth them as they sit too low to the ground and hit on things.
I have had them for bout 7 years and Are staritng to leak around the main collector on the bottom. I also found that When I fitted them I los bottom end Torque but I gained a bit up the top end.
I think they would be better for a full race engine.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
PostPosted: Mon Feb 21, 2005 12:52 pm
resident alien
resident alien
Is there any particular area where there are any codes on extractors? I've been trying to find some on mine but there's a bit of rust on the exterior
PostPosted: Mon Feb 21, 2005 2:08 pm
i doubt it , how do you mean 'code' ? "LCB" ? "3 in to 1 " ?
this is the maniflow med. bore LCB
this is a 3 in to 1 extractor
lookin for another clubby
PostPosted: Mon Feb 21, 2005 2:36 pm
And, the race 3-1 is different again- like an LCB but with 3 equal length pipes that go right down round the bottom and join up.
NFG for a road car, can't stop 'em leaking I've been told.
PostPosted: Mon Feb 21, 2005 7:33 pm
resident alien
resident alien
I know the meanings and look of the LCB and 3into1's. By 'code' I mean a way to get a make, model & size of the extractors similar to the way you can distinguish engine blocks and head etc.
Just found out from the previous previous owner (yes that IS 2 previous) that they are brownrig? do'nt know what size though and I could already see that they are LCB.
What exactly is done when you perform a 'mild port & polish'?
PostPosted: Mon Feb 21, 2005 8:08 pm
what lcb's do i have?
they're definately lcb's but u can't see the 2 pipes join to 1. it goes under the car before u can see it.
any ideas?
PostPosted: Tue Feb 22, 2005 2:43 am
...look under the car? But seriously if they are no sliding joints before the manifold curves under the car then its probably maniflow or some copy of them. I hear from many sources that as long as the shoulder right at the top (exhaust ports) is nicely curved and wide and the bore is consistent throughout they'll all perform the same.
A certain Sydney welding engineer might tell you otherwise though.
PostPosted: Tue Feb 22, 2005 2:45 am
BTW Kev did you get the clamp kit with the maniflow? coz I've swaped the sonics for a Longman LCB and its looking good but no clamps at all.
