It is currently Fri Jul 18, 2025 11:30 am
 Post subject: a+ block?
PostPosted: Thu Feb 17, 2005 9:05 am
hey guys just been thinking this morning, can a pre a+ dizzy be fitted to a a+ block? ( i know about drive changes, but is the mounting face the same?
lookin for another clubby
PostPosted: Thu Feb 17, 2005 1:46 pm
Not to sure I think the mouting bracket is different but I would need to look at the one in the shed to see if the whole dizzy is same and ahs the provisions for the old style mounting bracket.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
1970 Mini K, 1380cc, 1.75 HIF SU, 30 70 Cam, 2" Zorts
1969 Mini K, Stock Standard and Orginal. (Slow as Hell)
PostPosted: Thu Feb 17, 2005 2:18 pm
Hey,
I have a rear wheel drive a+ in my sprite and all i had to do is change the drive... all the rest is the same, cant b sure ther the same asa mini tho...
-Cam :lol:
IS NOW BACK ONLINE AFTER SOMETIME..... SORRY TO ALL, FOR NOT REPLYING TO PM'S!!
PostPosted: Thu Feb 17, 2005 6:25 pm
I'm about to convert my Pulsar D4R85 dizzy from A series to A+ for Barney's 1293.
The A+ drive dog is different, the roll pin is smaller, and once I run a file around the Pulsar dizzy's body (or stick it in the lathe) the A+ finger clamp will work fine. :wink:
Diameter and body length of A series and A+ dizzys are pretty much the same.
PostPosted: Fri Feb 18, 2005 11:55 am
fair enough, im just thinbking if i get an A+ block will i be able to use my honda dizzys?
PostPosted: Fri Feb 18, 2005 8:20 pm
Yes, I've take mine out already and it will fit. Maybe next week, A+ motor is still not quite in car yet.. 8)
PostPosted: Sat Feb 19, 2005 12:53 am
The mounts on the A+ 1275 motor (from what iv seen) use a diffrnt type of mount,but if you buy a late nuff A+ motor it may well have elec. ignition in it?
OR
are you already in on the pulsar dizzy thing?,they do sound like a good idear,but id be tempted to leav my stuff mini with a pertronic kit if i could
PostPosted: Sat Feb 19, 2005 5:59 am
OR
Yes, A+ block mounts it different but the Pulsar dizzy can be modded easy to do both.
I've had a Pertronix- they work, but they don't fix the worn bushes and advance mechanism that are a feature of all old Lucas dizzys.
I have yet to find a Pulsar dizzy with any slack in it- they are beautifully made by Mr Hitachi.
re the late electronic Lucas- much of the above applies, and they have had problems with external ignition modules. Pulsar dizzy has it all under the cap... neater system. :wink:
PostPosted: Sat Feb 19, 2005 10:42 am
Do the pulsar dizzys use a ignition coil of there own,or can it be wired to the mini one already on the car?
PostPosted: Sat Feb 19, 2005 12:04 pm
Pulsar dizzy uses a standard 1.5 ohm `resistor' coil (but without a resistor), not the 3 ohm Mini one.
For $40 at the wreckers we get the Pulsar dizzy, coil, cap & leads too..
Bosch GT40-R coil works OK with the Pulsar. :wink:
