I was at a mates and he is getting rid of some of his stuff and he has two cranks there (that i saw amongst others) that are 12G1505A in raised lettering. By veiwing with the naked eye one has larger journals than the other.
* Is the one with the larger journals a large journal 1100S crank??
(or i really have to measure it ?)
12G1505 is large journal.* How likely is it that it would be cracked (ie was it a common fault?)
50/50, get it crack tested before shelling out $$$.* Also i have been told that 1100S blocks are better for performance than S blocks because they are stronger without the removable chest covers.
(plus my mate doesnt want me to use an s block because it is an S block)
Yes they are a stiffer block (and heavier).* Do i have to use S conrods to stroke it?
Yes.* So what would an appropriate price be to pay for the 1100S block and journal with and without rods??
Block I wouldn't pay more than $250,
Crank it depends- whether it needs a grind, what size it's worn down to. $50-$300 depending on how lucky you are.
If worn work on paying $150 approx for a regrind, add another $100 if you want it stroked.
If stroking it I would get it wedged too, then balanced.
If it's cracked, walk away.
1100S rods- $50/set, S ones- $100/set and up.Thanks everyone for your help because this is a learning curve for me, and something i have little knowledge about, but am keen to learn
Thanks Brenton
