It is currently Mon Jul 28, 2025 2:06 am
PostPosted: Sat Feb 14, 2009 4:48 pm
First of why does the gear stick start spinning around when i lift it up to engage reverse???
Secondly has anyone got a picture of the rear seat belts in use as i have never seen or been in 1 and they look odd and cant figure how they go?!
Thanks in advance!
PostPosted: Sat Feb 14, 2009 7:24 pm
Basically does the buckle go in the middle or outside!?
PostPosted: Sat Feb 14, 2009 7:27 pm
The buckles are on the outside. The belt that mounts on the left of the parcel shelf goes to the right buckle and the one on the right goes to the left.
PostPosted: Sat Feb 14, 2009 7:29 pm
mine does that too sometimes i just keep it straight and try not to twist it , or put it back into neutral and try again
PostPosted: Sat Feb 14, 2009 7:32 pm
re the gearstick, probably the steel pin that locates in the gearlever's slot to stop it turning is worn away and needs replacing.
PostPosted: Sat Feb 14, 2009 9:40 pm
It`s normally the slot in the stick that wears ... & quite often added to the fact that the little pin in the side of the housing often bumps a bit outwards.
PostPosted: Sat Feb 14, 2009 9:56 pm
This space for rent
It's posessed, don't sweat it.
PostPosted: Sat Feb 14, 2009 10:03 pm
I question both the above thess are at the gear stick end and would be for all gears. I'd say its the linkages behind the motor or those brass buches which i need to replace also
PostPosted: Sat Feb 14, 2009 10:17 pm
Nah Gaf - hes talking about a Rod change Im guessing - its the pin/stick worn in the housing under the floor as the others have said
Daniel
PostPosted: Sun Feb 15, 2009 7:06 am
Sometimes the hole in the alloy housing wears, I fixed Spiro the Moke once by drilling it to 5mm and press fitting a bigger pin in there.
Users browsing this forum: Bing [Bot] and 86 guests
