It is currently Mon Jul 28, 2025 7:02 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Sat Feb 14, 2009 6:01 pm
http://www.youtube.com/watch?v=GepuJfZOis8&feature=related
http://www.youtube.com/watch?v=jDp8yjdFAD4&feature=related
& one of my favourites,,, a piston actually hits & smashes this guys hand OUCH!!!
http://www.youtube.com/watch?v=K2GLrZSTsI8&feature=related
edit--> Oh & this one too :-)
http://www.youtube.com/watch?v=aRYwrHQyJAM&feature=related
PostPosted: Sat Feb 14, 2009 8:20 pm
blown up just one for me,
was doing a motorkhana at monarto in 06, i had no center oil pick up at the time and a constant right hand corner at 4k led to loss of oil on the pick up and the engine seized.
took the plugs out pushed it back and forwards till it freed the bearings and got it running again. But i had a nasty big end rattle on 3 and 4. completely smeared the bearing over the oil holes.
PostPosted: Sat Feb 14, 2009 11:18 pm
Interesting. some of the piston/brgs could be explained. broken crank/rods????????
Consider this
1 the clutch bake plate and pressure plate are bolted together and attached to the flywheel with 3 metal strips.
2 the dia. of the backplate is 225mm
3 the weight of the back plate and pressure plate is 7kgs
4 engine running at 6000 rpm ie 100 revs /sec
the circumference of the back plate is travelling at 71 meters/sec
when the clutch is used the back plate moves and as there is NO positive location to crank or flywheel andmoves off center and the whole crank/flywheel goes out of balance.
This out of balance force can be calculated by using a formula called centripetal force and the vibration transmitted thru all the reciprocating parts[crank/rods/pistons and brgs] is calculated with torsional vibration formula. all IC engs have torsional vibration and critical noduals, the point at which maximum stress occurs.
I was shown a practical demo of this years ago. One of the engineers where I was working had a min eng set up on test bench. He cut a hole in clutch housing to see bolts in pressure plate. Maked around this area with chalk. Ran eng to 5000 rpm and using a strobe light we watched the bolt. Then activated the clutch, you could see the bolt moving around every time the clutch was engaged and dis-engaged. It quite often did not return to original position. This meant that this whole 7kg mass was going out of balance.
This out of balance force is like bending a piece of metal, the amount of deflection and the no. of times determins when it will break.
What is the point of balancing a crank/rods/flywheel whe you have this out of balance force occuring unless the reciprocating mass can be positively located and included in the balancing.
Man these engines are good for the abuse we give them
www.minisprintgt.com
PostPosted: Sun Feb 15, 2009 1:44 am
Only blown up 1 engine........2007 on Philip Island (chasing and catching a purpose built race mini) coming up to the hayshed ...no warning, no loss of oil pressure, no knocking, etc .......just BANG :!: :!: no.2 pulled the thread out of one of the rod bolt nuts and the other rod bolt let go after a bit of 7.500 - 8,000 rpm hammering, piston stuck at the top of the bore crank came arond and made short work of the bigend of the rod and damaged the wall of the lock, bent the cam and crank (block is able to be saved :D ).
PostPosted: Sun Feb 15, 2009 6:58 am
Consider this
Good analysis there David, I'm wondering if the later Verto clutch setup is any better?
These have the pressure plate/flywheel setup reversed, where the pressure plate is bolted to the crank, and the `flywheel' floats... it is all still hung a long way out from the rear main bearing. I bet that doesn't help crank durability either!
PostPosted: Sun Feb 15, 2009 8:02 am
An interesting read, David. And I agree they hold up very well considering the hammering they recieve.
I have spun a big end in a very tired 1098 in my van when I was about 16yo on a mini cruise. :roll: Stupid kids. :lol:
Matt
PostPosted: Sun Feb 15, 2009 9:30 am
Never actually blown up a mini engine, although I have put the clutch out through the housing :shock:
